I am build a datacut CNC (60x38x8), which calls for a 1/2" Z lead screw. I am having trouble fitting the antibacklash nut in the space provided (30mm using hiwin #20 bearings and rails). I can make a 1/4" nut fit, with some trimming on the flange. Is 1/4" too small for Z axis? Other options? thanks |
| i have 1/4 20 tpi screws on my maxnc. They are a bit flimsy and will whip. Both ends need to be supported. With it only being 8 inches of travel and hopfully not alot of weight it might be able to do it. If your cutting harder materials, even wood, then I would slow do the plundge rate. You can bend them pretty easy. But my maxnc has a 18 in table and it moves ok. |
| Need A Quote- RFQ: Small (3"x5"x1/2") part from dimensioned drawings in Aluminum or stainless | octathorpe | Employment Opportunity | 6 | 06-23-2008 08:14 PM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 12:23 PM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 09:42 PM |
| Ball Screw or Lead Screw? Which is Better? | ljoe1969 | DIY-CNC Router Table Machines | 4 | 07-28-2004 09:49 AM |
| Ball Screw and Lead Screw | ljoe1969 | DIY-CNC Router Table Machines | 9 | 11-21-2003 09:06 AM |
