Old 10-29-2008, 06:18 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question Need two 12mm 4 Bolt flange bearings
I have looked on various sellers on Ebay and Amazon and cannot find any 12mm 4 bolt flange bearings, tons of 1/2" though.
I need two of them.
Can anyone tell me where I can get a couple.
Hager
Old 10-29-2008, 08:06 PM
Moderator
bp092 is on a distinguished road
Why not just go with 1/2" http://www.thebigbearingstore.com/se...-Flange/Detail
and make it work? 12mm is what, .47? 1/32 isn't a lot of play especially with 2 set screws.
Old 10-30-2008, 01:43 AM
Mr.Chips's Avatar
Gold Member
Question Need two 4 Bolt 12mm Flange Bearings
Thanks for the suggestion but as you say 12mm = 0.474" that's 0.026" smaller than 0.500".
This would put added stress on the ball and the flex connection, I want to build as best I can.
If I can't find a 4 bolt 12mm flange then I have two options, (1) make a flange using HDPD (SP???) or (2) turn the 12mm portion down to say 0.250" and sweat a sleeve over it to bring it up to 0.500". The latter is what I'm leaning to.
See Drawing below.
When you are building out of found inexpensive parts there is always challenges.
Hager
Name:	4 START BALL SCREW.jpg‎
Old 10-30-2008, 03:22 AM
Fiddlemaker5224's Avatar
Fiddlemaker5224 is on a distinguished road
Post
(815)-654-1154
Address9926 N Alpine Rd
Machesney Park Illinois, 61115
Berry Bearing Co. Has what your looking for. We had alot of metric machines at the plant. We called them and could get the bearing by COB.
They don't have a web page that I could find. Also try other bearing suppliers in your area.
Old 10-30-2008, 11:22 AM
Mr.Chips's Avatar
Gold Member
Originally Posted by Fiddlemaker5224 View Post
(815)-654-1154
Thanks Fiddlemaker,
I'll give them a call.
Hager
Old 10-30-2008, 02:30 PM
Post update
Berry Bearing is part of Motion Industries.
https://www.motionindustries.com/mot.../mi/motion.jsp
I found his section.
Build Thread- Phoenix Modification 2.0: Flange Bearings Mr.Chips DIY-CNC Router Table Machines 4 01-25-2011 07:04 AM
12mm rods and bearings. first machine question srmaietta DIY-CNC Router Table Machines 7 04-09-2007 09:26 PM
Is 12mm/2mm ballscrew for Z-zixs router undersized? NC_jimbo Linear and Rotary Motion 7 03-26-2007 03:24 AM
Where can I find a 12mm 2.5 pitch lead nut woodturn Benchtop Machines 6 03-14-2007 12:17 AM
Bolt hole spacing on a flange Bill Wann Autodesk Software (Autocad, Inventor etc) 4 03-15-2006 08:11 AM
