Old 10-29-2008, 07:33 AM
jwest is on a distinguished road
really budget first cnc
hey, as part of a college project I've decided to undertake the task of designing and building a cnc router. The project is funded by the college so money isn't an issue, but i think it would be a much more exciting challenge to build it for the very bare minimum, so I'm looking for any ideas that can keep the cost down, so far I'm thinking.
75cm (30") by 50cm (20") cutting area, and a few inches in the z.
Having a stationery gantry, the workpiece moves instead, i think this will be cheaper as the workpiece could be clamped down to a really small base, simply a bar that slides on rods at either side.
X,Y and possibly Z will use timing belts and pulleys, and only 1 motor on the X.
Construction mostly of plastic should keep costs down as well.
Obviously I'm new to all this so any suggestions at all, would be really helpful.
Old 10-29-2008, 07:50 AM
TOTALLYRC is on a distinguished road
Search the zone, there are a bunch of post about low budget routers.
Old 10-29-2008, 11:05 AM
lovebugjunkie's Avatar
Gold Member
lovebugjunkie is on a distinguished road
Might want to look at this. http://www.rockcliffmachine.com/
http://www.cnczone.com/forums/rockcliff_machine/
CNC On A Budget - Burnt! Rhodan CNCzone Club House 14 01-18-2011 01:55 AM
Table saw on a budget jack g WoodWorking 9 06-04-2007 01:15 AM
Budget changed, now what..? Rekd Benchtop Machines 20 03-09-2005 09:15 PM
Need Ideas for a budget, and... Nonoriginal Benchtop Machines 5 02-13-2005 05:09 PM
$6k budget for cnc mill, please help! touser General Metal Working Machines 5 09-30-2004 10:14 AM
