Old 10-31-2004, 06:44 AM
Gold Member
CRFultz is on a distinguished road
1/4 to 1/8 collet adapter?
Can anyone tell me where I can get a 1/4' to 1/8" collet adapter for my router? I have a Dewalt 2 1/4 hp model DW618. The quick change adapter by Porter-Cable sounds good but I'm not sure if it will fit the Dewalt.
I would like to find a precision collet of some kind. I have read that the die grinder adapters have way to much TIR and will break a small bit. I haven't had much luck in seaching the web in locating a good quality piece. There is reference to one on the " PreciseCut" web site but the link is no good.
Thanks'
Chuck
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
Old 10-31-2004, 06:50 AM
ger21's Avatar
http://store.yahoo.com/porter-cable/porcab4214to.html
Old 10-31-2004, 07:52 AM
Gold Member
I'm looking for something along these lines:
er11 collet
or this:
The pic is the one I want but I can't locate a seller.
The one on ebay will work but it would have to be cut down
Old 04-15-2010, 12:23 PM
cwdurand is on a distinguished road
Thanks'
Chuck
This is probably what you need. It's likely where the machine came from and so they just didn't tell you you need this to use 1/8 inch bits.
http://www.cadcamcadcam.com/sleeve-adaptor14to18.aspx
or the dual split, which looks more feasible.
http://www.cadcamcadcam.com/sleeve-a...to316-1-1.aspx
Old 04-15-2010, 04:10 PM
marzetti is on a distinguished road
http://www.precisebits.com/gateways/ColletsNutsHome.htm[/URL]
Old 04-15-2010, 04:52 PM
bdsorcic's Avatar
bdsorcic is on a distinguished road
Might want to try 'http://www.gpcollets.com/index.html' They gave me good service... !
Old 04-17-2010, 01:54 AM
lunchtrayrider is on a distinguished road
as long as this is dug up from the dead, maritool sells a straight shank tool holder
http://www.maritool.com/Straight-Shank-Tool-Holders
no experience but i'm guessing someone here has used it.
Calculating draw bar force on R8 collet h3ndrix General Metal Working Machines 8 07-27-2005 04:51 PM
precision collets twombo DIY-CNC Router Table Machines 8 05-28-2005 10:52 PM
Your opinion on adapting my router collet MrBean DIY-CNC Router Table Machines 5 12-03-2004 11:02 AM
1/4 Carbide Aluminum Feeds? Cold Fusion General Metal Working Machines 3 08-09-2004 08:59 AM
Sealing a collet? HuFlungDung General Metal Working Machines 6 04-13-2003 05:36 PM
