Old 10-26-2008, 08:09 PM
GlacialWanderer is on a distinguished road
Table top clamping system suggestions
I've built my first CNC machine and it's working pretty well. The biggest issue with it now is that I didn't include any good way to clamp down the pieces I'm working on. I'm looking for suggestions.
The only idea I have found is buying a plate of aluminum and put threaded holes in it. I'm imagining a big plate of alluminum (3'x3') would be expensive. I'm also not sure what thickness I'd need.
If you want more details on my machine, I have a build log here.
I'd really appreciate some of the people with experience on what worked well or didn't work posting here. Also if you can suggest suppliers that would be great.
Old 10-26-2008, 08:45 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
ive got the mdf t slot which works great for holding stuff down and is cheap but my personal favourite remains the hot gluegun , it holds well and is easily removeable
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 10-26-2008, 08:52 PM
MrWild is on a distinguished road
Half inch cast jig plate. Maybe Widget-master would make you a T slot plate. That'd be ideal.
Rotary Table Suggestions wrk24wheel Benchtop Machines 11 05-07-2008 11:58 PM
Need Help!- Clamping work to table jeffmorris DIY-CNC Router Table Machines 6 04-24-2008 08:20 PM
suggestions for plasma table components stanglou General Electronics Discussion 1 11-14-2005 01:18 PM
5 axis control system need suggestions pab Commercial CNC Wood Routers 6 02-06-2005 10:58 PM
Need suggestions on components 5 axis control system? pab Mach Software (ArtSoft software) 0 01-19-2005 04:34 PM
