Old 10-24-2008, 06:43 PM
Eurisko is on a distinguished road
Thread Milling On A Homebuilt, Stepper-Driven Machine ?
Just wanted some input on the feasability of thread milling with a homebuilt setup. Since the spindle rpm is independent of the axes movement, I think that it would be much more viable than tapping.
Anyone with a homebuilt machine have any success with this?
What software? (can Mach handle helical interpolation?)
Are you using servos and ballscrews, or steppers and threaded rod?
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 10-24-2008, 11:40 PM
Alan Wright is on a distinguished road
I've done this with Mach3 and my own code, and have read of others doing the same around here. I don't know of commercial software that does this, but the g-code is actually quite simple. It's easiest with a rotary table, as you just combine a rotary move with a Z move. You can do external and internal as well as left and right hand threads with very similar code. I've only done it with ballscrews or other low-backlash setups, but the rotary table method avoids some XY backlash problems.
Alan
Old 10-25-2008, 04:45 AM
wjfiles is on a distinguished road
Thread milling
I use Mach 3 and NFS wizards, and a single point internal threading tool for internal and external threads. I doubt if you will find anything simpler and easy.
WJF
The More I Learn The Less I Seem To Know
Old 10-25-2008, 10:59 PM
Thanks for the information. I'm still in mid-build, would like to thread some holes in an aluminum plate for my router table. Not quite ready for it just yet, but thread milling will save me a lot of work.
I hate tapping holes by hand
Need Help!- Mach3 Problems With Homebuilt Machine ltl2007 CNC Plasma and Waterjet Machines 4 10-05-2008 09:47 AM
Thread milling in a machine center jorgehrr G-Code Programing 30 08-05-2007 07:58 PM
Homebuilt CNC Hole Drilling Machine nitrosaturn DIY-CNC Router Table Machines 8 11-14-2006 02:44 AM
Homebuilt machine accuracy atomgonuclear CNCzone Club House 15 02-13-2006 08:57 AM
What stepper motor, for a milling machine? CNCadmin Stepper Motors and Drives 6 03-23-2005 03:09 PM
