Old 10-22-2008, 08:48 AM
browndog is on a distinguished road
First CNC..Where does one start
I'm fasinated by these machines. Been lurking a bit and want to build one. I have a very detailed wood shop so tools aint a problem. I'm curious what a begginer CNC wanna be would build. What model i.e jgro etc would you suggest trying to build. I like the MDF idea because it's not real expensive.
Please, help a wannabe out :
Thanks in advance
Old 10-22-2008, 10:12 AM
Med-Pac is on a distinguished road
There is almost an infinite amount of options to consider. Budget, table size, the sytle of your machine (do you want the gantry to remain stationary and the table to move or vice versa), travel/feedrate speeds, quality of cut, tolerances are just a few. What are you planning to cut with your table?
Beings this is your first build I'd say the MDF idea is a good one from the cost side, but it won't be as fast or as sturdy as an 80/20 extrusion or a steel table would be.
Hope this helps,
Mike
Old 10-22-2008, 10:36 AM
Looking to cut wood and maybe plastics. Signs etc. Small wood parts. I was looking at joes CNC but I dont think the plans are free or I cant seem to find them.
Looking for the table to remain fixed. Nothing too big either 2x2 or 2x4 or close to that.
Old 10-22-2008, 10:52 AM
ger21's Avatar
Joe posted a link to the plans, but I don't know where it is. Ask him in the "Joes" section. If you have good woodworking skills, Joe's 2006 is probably the way to go.
Old 10-22-2008, 11:03 AM
cabnet636 is on a distinguished road
saw this this am and found it to be good reading
there is also another article on new cnc in this months issue
http://www.woodshopnews.com/index.ph...rchives/497072
Old 10-22-2008, 11:23 AM
BigMike4u is on a distinguished road
Joes 2006 plans should be here.
http://www.cnczone.com/modules.php?n...warticle&id=71
Old 10-22-2008, 11:27 AM
Got em..Now trying to figure how to print detailed cut list etc. I have never used solid works or sketchup
aghhhhhhh
Newbie- Where do I start? javafiend DIY-CNC Router Table Machines 7 03-01-2008 01:50 PM
How do I start woodlice Controller & Computer Solutions 1 02-28-2008 05:52 PM
Where Do I Start? Pressurerelief Tormach PCNC 12 02-22-2008 09:54 AM
Single start vs double start ballscrew. darik Linear and Rotary Motion 13 03-21-2007 07:53 PM
start in edm logos CNC Plasma and Waterjet Machines 2 04-08-2006 11:44 PM
