Old 10-22-2008, 01:03 AM
EvanZ is on a distinguished road
Not getting motion.
I have a CNC4PC C10 Breakout board, with mach3 on the PC, I have a chopper drive from Hubbard CNC 60Volts at 20Amps Antex Powersupply. I have everything hooked up for one axis as is shown in the C10 userguied. I get nothing but when I trigger the E-Stop Mach does see it. I can take the inut swres and manually pulse them and make the motor try to step. What in the world have I done wrong, what are things I should look for.
Sorry this is so brief, but alas it is late and I need to crash.
Also Sorry I have been missing from the CNC world for so long, women and Going back to school at ISU has taken up most of my last year.
I will be looking forward to all the help I can get from your great minds,
Night all,
Evan
PS Thanks...
Evan.
"You're making WHAT?"
Old 10-22-2008, 02:03 AM
TOTALLYRC is on a distinguished road
Night all,
Evan
PS Thanks...
My best guess from what you said is that you have the pins not set correctly in Mach3. Either that or your parallel port cable isn't any good.
Old 10-22-2008, 02:30 AM
I just checked the pins, they were wrong, I changed them but got nothing. the c10 is giving me 5V out on the step terminal, if I pull that wire out of the driver the motor makes a step, if I tap it, it steps. I have power on the step pin but no pulses, what gives?
E
Sorry folks for the spelling/grammer, I'm sleeping the best I can. Not easy when my machine is not running. I keep waking up to check CNCZ
Evan.
Old 10-22-2008, 02:37 AM
E
If you have a meter, set it to continuity or ohms and make sure that the paralllel port cable is showing straight thru connection and that none of the pins is connected to each other.
Mike
Old 10-22-2008, 05:07 AM
Harpye is on a distinguished road
I'll try to give you a short checklist - if anyone has additional ideas please feel fre to update:
00 check Centronics cable
1.0 read specification of Centronics input interface of interface board (
voltage level/ ranges for hi/low signal)
1.1 measure logical level on changing output on "no load" state ( cable
not connected to board but to PC)
1.2 connect cable to board and measure hi and low under load -the
current sink of the board might lower the voltage level of the
signals
Some newer Mainboards use Centronics drivers for notebooks which are specified with lower high level, so this check should compare the incomming signal with the required levels. -> if this is ok the interconection between PC and controlboard should be right
2.0 Take a Mach III template that is made for Milling -
2.1 Check your MachIII adjustments for the channel / axis
2.2 to make sure, there is a high low signal change on step watch your
Mach output monitor and compare with Centronics pin output
( take care of e-stop or other disenabeling signals - ( limiters or
reference switches)
If there is no fully comparability between MachIII monitor and pins
check the Centronics installation ( adresse(s) if you have several -
did you use the right?)
3.1 I had a case that Mach trial was installed but didn't work 100% what
means the pulsor (realtime clock reference which is placed below the
windows core) was not working succesfully what means
reinstallation, but this is a bit difficult for the ineffective part ist not
easy to uninstall - you perhaps should try to contact you dealer to
help with - or change to EMC
4.1 Anything works fine until now? You have your steppers left as a failure
source - are you able to measure a current trough both of the coils
within a series of 4 Steps ( your Amp should be programmed in fullstep
mode for this). If not, you should check the connection scheme - beep
through both coils -
measure coil resistance ( compare with spec and connect correctly!)
HJ
Why reach for speed, when you could have precision instead!!!
Old 10-22-2008, 01:09 PM
Ok school definitly has my brain turned to mush. I totally went glossy-eyed when I read this...
Does anyone speak stupid?
Sorry
Evan
Evan.
Old 10-22-2008, 01:59 PM
Sorry
Evan
I speakem das stupid.
All kidding aside, I understand what Harpye is trying to say, and agree with some of it,but it will take a while to translate into clearer english. I will post later when I get up if nobody has done so.
Old 10-22-2008, 02:34 PM
Sorry about my ( very reduced) trial to explain but English is not my mother thoung - as you probably already found out yourselves... Beg your pardon, but if it is too stupid - tell me and I will quickly erase it !
Hj
Old 10-22-2008, 07:17 PM
Harpye NO! lol you are not the stupid on I AM! I have been so outta it with school and no sleep I just didn't comprehind what you were saying. I'm taking 25 hours of houners engineering credits this semester. Gag me! Why did I do that to myself ! With 25 hours a week of class and 48-50 hours a week of homework plus my hobby/school project I'm pretty well living in a fog.
Ok now that my rant is over. I built a simple test card were I cut the end off of a printer cable and soldered the wires onto a blank circut board and gave myself a easy test board then. I got 3.365Volts in one position on the X axis dir which I have as pin 3, and I have .60 volts in the other direction. I get this on all three axis output pins.
I checked and have the same signals with the db25 cable on the c10, so the cable is good. I THINK this is what I was told was the correct singles for direction.
Thoughts everyone?
Evan
Evan.
Old 10-22-2008, 08:33 PM
wow I can't even spell. Sorry about that fellews. I just turned on the equi[pment and I'm getting some odd movments outta the motors, it only does it with mach sending signal. wth?
Evan
Evan.
  #11   Ban this user!
Old 10-23-2008, 12:10 AM
Evan - I know what you mean ... the daily situation after 10 hours of work!
Ok - you need two signals (- Clock and Dir -additional the enable signals .... /e stop & /limiter for enable - could also be used for reference switch.) There are some SW tools for free on the web which can monitor the Hardwareside of your Centronics - as long as you have made sure that the 3,65V are available under load of the board, too and that the level is definitely high enough to be accepted by the board ( is this a notebook??? - 3,36V seems rather low to me) - do you use an opto interface) - you should get this spec from the manual - if the manufacturer is a serious one, or out of the Centronics driver spec if you are able to read the marking on the IC.
second is .... that some signals to use are low active - could you find out which ? -
If you want to drive the Motor manually you could fix all the other pins to certail level and switch the clock between high and low what causes the motor stepping !!! but you have to make sure to take the right voltage for Hi - level!
At the point ... Could you make sure that the Centronics spec of you PC is compatible with you centronics spec of the controller card in regarding the voltage level . That is one main reason why many notebook users switch to USB based systems ( but I don know if Mach does support this )..
Hj
Good luck on research and developement!!!
Hj
  #12   Ban this user!
Old 10-23-2008, 12:12 AM
Dear Harpye.
The problem with these forums is you can't see the expression on my face as I type. I was not trying to make fun of you, I was laughing with EvanZ.
It is very clear that english is not you native language, but it takes guts to post on a forum when that is the case.
I will try to translate from you rearlier post.
1. Cenronics is another name for printer cable but it normally has a different end like you would see on a pport printer. ( centronics connector)
1.1- 1.2 What he is saying in a nutshell is to make sure that you are getting the proper output voltages from the breakout board because most newer pports output 3.3v instead of the 5v of the original ports and a good breakoutboard will correct this problem.
2.0 Select Mach3 mill, not plasma or lathe.
2.1Verify you raxis settings inside of Mach3
2.2 Use a meter to make sure you are getting the proper signals on the proper pins and that the signal is going high and then low. The direction will only go high in one direction and low in the other. The step will go high and low with each step. set it to a low rater or your meter will not see it as it will be way too fast to see. Make sure your e-stop is connected correctly and that you are not on a limit switch or something.
3.0-3.1 It could be possible that Mach3 didn't install correctly and that the pulseing engine is malfunctioning. It can be a pain to completly uninstall mach3 and Maybee you should try EMC.
4.1 If everything checks out to this point your steppers are the next problem. you should have current going thru both sets of coils within 4 steps. Set the motor drives to full step for this test. If not, use you meter to check for continuity in each coil.
2.3
Now for my help. If you are getting 3.3v out of the breakout board, verify that the stepper drives will run on that voltage. Some drives require a high signal near 5 volts.
your low of .60 volts sounds good IIRC as long as it it below 1 volt you will be OK. BUT!!!!!! check what you stepper drive will accept for a high voltage and a low voltage. If you are on the ragged edge of their specs, you will have problems.
If your meter has a frequency setting, use that and test the output of one of the step pins, it is a lot easier to read a frequency for the steps than it is to se the voltage change. I think.
Your readings on the direction sounds good to me.
Need Help!- cnt motion cnc DietzWoodPROD. Commercial CNC Wood Routers 3 04-19-2008 08:06 PM
Ok Now what? No motion at all SpookyDad Xylotex 5 07-06-2006 04:21 PM
Need y-z motion help! dtuom Linear and Rotary Motion 3 12-03-2005 12:03 PM
motion? hpghost DIY-CNC Router Table Machines 3 04-04-2005 11:59 AM
No Motion FLUTE HEAD Xylotex 2 02-15-2005 09:33 AM
