Old 10-07-2008, 11:05 PM
Jkirk3279 is on a distinguished road
Retrofit Precix Router
Hi.
There's a lot of builders in this forum, so I thought this might be the place to ask.
I have a Precix 9000 HPGL router. I want to update it to run GCode.
So, can I just replace the controller with a PC loaded with a Gecko board and maybe a buffer box?
Will I need to replace the stepper motors with servos or should I keep them?
Servos might be a worthwhile investment, as I've seen steppers slip when run too fast.
Newbie- Convert/Retrofit old Precix HPGL controller to G-code Blluitt Commercial CNC Wood Routers 30 01-13-2012 10:42 PM
Precix Router Industrial series juanleal Commercial CNC Wood Routers 14 03-10-2008 04:20 PM
cnc router retrofit japco43 General CNC (Mill and Lathe) Control Software (NC) 0 01-03-2008 12:42 PM
Precix Cnc Router with a ATC dighsx G-Code Programing 6 07-01-2006 05:29 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
