Old 05-21-2003, 07:37 PM
georgebarr is on a distinguished road
closed loop
I am trying to put together a "closed loop" cnc system. I already have motors, encoders, gecko drivers, and power supply. Can anyone advise me how to use my existing hardware to put together a closed-loop cnc system? I have looked the FlashcutCNC. Can the flashcutCNC software and signal generator interface with all my hardware? Any advise is appreciated.
Thanks,
Old 05-21-2003, 08:06 PM
balsaman's Avatar
balsaman is on a distinguished road
I am pretty sure any software can be used with that hardware and it will be closed loop, providng those are the servo drives and servo (dc brushed) motors. Someone will correct me if I am wrong I am sure.
Eric
I wish it wouldn't crash.
Old 05-21-2003, 10:05 PM
kdoney is on a distinguished road
Which gecko drivers do you have?
Old 05-21-2003, 11:46 PM
I have the Gecko G201 drives. How can I make it into a closed loop? MiniTechs web site at www.minitech.com is selling the flashcut cnc software and signal generator on sale for $800 which is regularly at $1100. I am highly considering getting it at $800 before the sale ends.
Old 05-22-2003, 12:42 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Please let me clear the water about the Gecko servo closed loop function. This servo system IS closed loop but only back to the Gecko drive not back to the PC and software. The Gecko stepper driver has no closed loop function to the driver like the G320/340 does.
If you want true closed loop function back to the PC and software you must find the software first that will handle the input information from the encoders. I believe that 'DeskNCRT' will handle the closed loop function back to the PC. You will need to do some research on that software.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 05-22-2003, 06:54 PM
I think I can do close loop better. Jon Elson sells a universal controller which take step and direction and does an on-board count down for closed loop control with any standard driver. $200
Old 05-22-2003, 10:31 PM
HomeCNC's Avatar
You still need the software to handle this closed loop data.
Old 05-23-2003, 11:03 AM
That is correct.
Old 05-23-2003, 05:30 PM
Thanks for the information. I decided to go with Jon Elsons Universal Stepper Controller. It only cost $200 complete. It can handle upto 4 axis. You can buy a second USC and connect both to the same parallel port for upto 8 axis. It handles all of the switches and relays. It only runs under EMC but he promises to make it work for Mach2. This flashcutcnc for $800 on sale only handles 4 axis and not any more.
Thanks,
Old 06-01-2003, 10:39 AM
wjbzone's Avatar
wjbzone is on a distinguished road
What are the advantages of having closed loop back to the software vs closed loop back to the gecko?
Bill
Closed loop control with linear encoders Xerxes LinuxCNC (formerly EMC2) 15 10-14-2007 03:04 PM
Open & closed loop totsandman Benchtop Machines 3 05-07-2005 09:49 AM
Closed loop....open loop? DAB_Design General Electronics Discussion 10 06-26-2004 05:02 PM
Closed Loop Driver vs. Closed Loop Computer ojibberish Gecko Drives 3 06-08-2004 12:30 PM
Closed Loop motomitch1 Gecko Drives 13 12-24-2003 10:48 AM
