I'm doing test cuts on my finished CNC, still learning how to use the CAM program (MasterCam X2), so am a total newbie to CNC. I programmed (through Rhino) to do two series of circular extrusion cuts, one inside the other. But when I cut it in insulation foam, the straight cuts ends up becoming stairways (and oblonged oval instead of a circle because of this stairway problem). I haven't really fine tuned my newly finished machine yet. But still, I don't see the reason why it would go back to the entry point in a different location after each depth cut. Any ideas? I attached a pict of the end result. |
| ya, using Mach3. Also haven't done much one fine tuning yet. I guess I should do that before doing any more test cuts. Is there a list of things newbies should check through Mach3, in case I miss any and get frustrated down the line. Thanks |
| frustration....plasma cuts off during cuts any ideas? | gpnjuice | CNC Plasma and Waterjet Machines | 2 | 11-18-2007 06:45 PM |
| which cnc package cuts 2D parts with least extraneous cuts? | mbwittig | General CNC (Mill and Lathe) Control Software (NC) | 3 | 05-06-2007 06:29 PM |
| Need a straight answer... | WilliamD | Mach Software (ArtSoft software) | 3 | 09-14-2006 05:18 PM |
| Aluminum extrusion as a straight-line ball slide | Charlye | Linear and Rotary Motion | 6 | 04-21-2006 09:41 AM |
| Full Steps -vs- Micro Steps | DJB282000 | General Electronics Discussion | 10 | 12-28-2005 11:25 PM |
