Old 09-25-2008, 04:02 PM
matttargett4 is on a distinguished road
cnc plasma stuff
hi guys,
im new here so forgive me if i talk rubbish! i am planning an 8 ft x 4ft plasma table, have done quite a bit of research an was planing to use igus w single rails for the x, with a rack and pinion drive next to it on both sides to try to combat binding, a 1.25mm pitch is planned driven by a 18 tooth spur on each side direct onto a 12nm stepper giving a minimum step of 0.112 mm or 0.0044" if i can do 200 steps / rev and @ 1000 rpm could reach 22.5m / min or 880 " / min. igus double rail for the y and z axis with a single rack and pinion drive with the same motor and spur.
does this sound remotely credible? feel free to tear it apart id rather find out from a group of experts than throgh expensive cock ups!. willl mach be good to run it?
thanks alot
matt
Old 09-25-2008, 08:34 PM
Cartierusm is on a distinguished road
I wouldn't use 1 rail I would use 2. The point of the rail is carry the weight of the axis, if I get what you're saying you're going to use the rack and pinion as the linear slide. I just don't think it would be that good. Now are you talking about the Igus slides that have the teflon inserts? If so they suck for linear motion I have a whole bunch of them I bought when first building my CNC. I tried everything and they just don't cut it. Plus them have plastic parts in them that some of the slag from the plasma and sparks might not like.
artsy stuff lapuser General CAM Discussion 2 12-28-2010 03:26 PM
X3 Stuff pzzamakr1980 Benchtop Machines 1 09-12-2008 10:10 PM
new at this cnc stuff JAKE BISHOP CNCzone Club House 0 05-08-2008 11:47 AM
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
