Old 09-23-2008, 04:03 PM
LazyMan is on a distinguished road
Large Steel Channels
Does anybody know where to find 6 inch steel channels with a profile like this? I cant find any online metal stores that supply this.
http://www.cnczone.com/forums/attach...4&d=1166239979
Name:	Steel Channel.JPG‎
Old 09-23-2008, 06:25 PM
theweldor is on a distinguished road
That material is called "ship chanel". I am not sure if it can be found online. Some of my suppliers stock it and some don't. Check a couple of local steel suppliers if that's possible.
Old 09-28-2008, 07:06 AM
LeonM is on a distinguished road
Hi
I am building a gantry router with similar channels (150 and 200mm). It was relatively cheap for the size of the beams but be warned that the parallel faces are not very parallel and you will need to machine or expoxy them to get a flat surface.
Need A Quote- Need to fabricate a large steel plate with designs. alexccmeister Employment Opportunity 5 04-08-2008 11:09 PM
Whoops! Smoked all 4 channels? Riceburner98 Xylotex 19 07-14-2007 09:36 PM
Large Capacitors Jay C General Electronics Discussion 11 02-01-2007 03:04 PM
Large SCR DC Drive? DennisCNC General Electronics Discussion 2 01-06-2007 10:18 PM
Large Grinder Firebird0095 Employment Opportunity 0 05-17-2006 02:49 PM
