Old 10-18-2004, 08:10 AM
Tabor is on a distinguished road
1st Machine, need advice...
Hey guys
This is the machine I have been building for the last month.
I have a quick question in regards to limit and home switches.
I am considering using optical interrupters for the switches, I was wondering if anyone else has used these and if they have had any problems like shavings getting in the infrared path of the switch??
Or is this all to hard and I should just stick with simple micro switches?
Cheers
Old 10-18-2004, 11:33 AM
jgro's Avatar
Gold Member
jgro is on a distinguished road
Although I haven't used them personally, I would advise against it. What you end up with when machining wood is dust, and a lot of it. It gets everywhere. I wouln't trust an optical switch.
jgro
Old 10-18-2004, 12:25 PM
jeffs555's Avatar
jeffs555 is on a distinguished road
I was also thinking about optical for my first machine. It would be good to hear from someone who has actually tried it. A coating of sawdust would not block most optical interrupters, it would take a good sized wood chip to do it. Another option I had considered was magnets and Hall effect sensors or reed switches. I have some left over magnetic door switches from an alarm system that I might try.
Old 10-18-2004, 01:10 PM
buscht's Avatar
buscht is on a distinguished road
Interesting idea.
When I am in doubt, I go look at what the large professional machines are using. All the ones I have seen use simple micro switches. Why, I don't know , but I am sticking with proven technology.
Old 10-18-2004, 03:28 PM
jphagen is on a distinguished road
For the limits I used reed relays and a magnet.
Salvaged from a copy machine. If it will take toner dust
it will take anything except metal ( magnitizes when it is cut)
Old 10-19-2004, 04:38 AM
Looks like the interrupters maybe just an extra chance for a problem to occur. I will probably just use micro switches and be done with it, looks like it has work for everyone else.
Thanks for the feedback.
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 09:04 AM
Starting first machine, looking for advice. nuplowboy DIY-CNC Router Table Machines 2 01-17-2005 10:57 PM
Advice required for my next milling machine. pigifly General Metal Working Machines 2 12-27-2004 03:58 PM
Looking for 1st lathe machine JRoque General Metal Working Machines 6 10-29-2004 03:37 PM
My 1st CNC Machine chas DIY-CNC Router Table Machines 8 07-18-2004 11:36 PM
