Old 09-20-2008, 10:54 PM
johnmac's Avatar
johnmac is on a distinguished road
Y axis rails sharing the load?
When building the Y axis, how can I help to insure that the rails will share the load, rather than one rail carrying the load while the other just loafs along?
John
Old 09-20-2008, 11:57 PM
andy_ck87028 is on a distinguished road
place them horizontally?
That's what I did. The key consideration is the required Z axis clearance however if you build a longer x axis and have the y rails slightly further apart, then z axis clearance needs can be designed in.
I believe horizontal Y axis is better than vertical but many would disagree.
Am away for 2 wks so can't respond.
Andy
Drat, imperfection has finally stopped working!!
Old 09-24-2008, 09:59 PM
johnmac's Avatar
Andy, your right. But most DIY router tables have vertical rails, as does mine. I can see where anything less than perfect alignment will cause the Z to be carried by one rail. I guess this isn't a problem as long as the 1 rail is strong enough to support the load.
John
Linear Rails for the Z Axis Bird_E Industrial Hobbies (Support forum) 24 08-31-2007 01:45 PM
HELP selecting MOTOR size 1 AXIS 8 ft table with load 1000 lbs cjchands Mechanical Calculations/Engineering Design 1 08-07-2007 08:27 PM
Add a second set of rails to X axis..need advice. bgolash DIY-CNC Router Table Machines 5 05-31-2005 07:11 PM
Y-axis rails 2muchstuff Mechanical Calculations/Engineering Design 0 04-14-2005 10:01 PM
Axis load meters? DAB_Design General Electronics Discussion 3 10-13-2004 08:35 PM
