| I can't help with the overhead part as I built a dual leadscrew machine. Is this your first machine? What is your question?
__________________ My Solsylva machine (my first cnc) http://www.cnczone.com/forums/showthread.php?t=44336 |
| I don't recall seeing one built from those plans at all, but I haven't searched for it. The Solsylva designs are generally laid out so that adding length to the affected parts should be a relative minor problem. I recommend doing some research on whether the overhead lead screw arrangement tends to induce more tendency to bind the x axis though. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| The overhead leadscrew CNC router was the first machine that I built. Its working area is 20 inches by 17 inches. I want to make a larger machine with working area of 36 inches by 24 inches but I want to use the parts from my machine instead of making a brand new machine, especially the Y-Axis/Z-Axis carriage that I built out of aluminum. I will have to build a new larger frame and gantry. I'm not sure if I want overhead leadscrew or leadscrew under the base/table for X-Axis. Putting the leadscrew under the base/table would make it easier for me to put large pieces of wood or plywood on the table. Would 200 oz/in stepper motors that I already have be powerful enough for the larger machine? |
| They probably will be powerful enough but you could use smaller diameters cutters and less cutting depth if they are marginal. The larger dimensions wouldn't add a lot of weight to the the moving parts. Chances are good that the only axis that might be affected at all is the x axis if it has to move more weight. I would use them and see what happens before ordering new steppers. CarveOne
| New Machine Build- Richster's Solsylva dual leadscrew build | Richster | DIY-CNC Router Table Machines | 87 | 04-02-2010 11:52 AM |
| Welding Larger CNC Router tables Sub thread | jsage | Open Source CNC Machine Designs | 1 | 02-03-2007 03:19 PM |
| solsylva router plans | Booge | CNCzone Club House | 1 | 01-23-2007 09:37 PM |
| Onsrud Overhead Router | marksnwv | Open Source CNC Machine Designs | 2 | 11-18-2006 11:18 AM |
| Onsrud W1136AR Overhead Router | marksnwv | Open Source CNC Machine Designs | 0 | 11-18-2006 10:40 AM |
