| Hey all Just got my widgitmaster mini! It´s not running yet, but I´ll continue in the morning I have to say, the build quality of the router is outstanding!bad mobile pictures, but they´ll have to do for now Henrik |
| Heheh, yup. Cute it is I needed something with a handy size ![]() The motors are 205 oz/in from hobbycnc. Any disadvantage of having these instead of the smaller ones? The controller is the 4-axis pro board also form hobbycnc. no need for the fourth axis yet, but you never know.. ![]() This is my first router so it´s a learning experience for me ![]() H. |
| Well, the pictures from my mobile tends to be a bit fuzzy when there is low light conditions as in the pics above.. Anyway.. cut my first couple of parts yesterday! Nothing fancy, just a spiral from the EMC2 examples and a wing profile from the vectric cut2d examples. It worked great! Still, the inches to metric conversion bit is definitely one to remember, I thought I was going to take a cut at Z-0.25mm, but when that endmill plunged about 6mm down in the hard plexiglass I nearly had a heart attack ![]() Thanks for replying people! H. |
| I've been wondering about motors for a mini router also. Is bigger better? I plan on milling PCBs and maybe some alum faceplates if that is possible. Also, while looking at steppers, I noticed power supplies seem to be in the 24-48 volt range, but motors want 3.5 volts or so. Is this correct? Chuck |
CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Yes, thanks. Further digging I saw that. But thanks for confirming. What I have not confirmed is bigger is better... My thoughts are too big may be less fine? Of do you get better resolution with the smaller motors? |
#10
| Chuck Take a look at some motor specs, I have 1.8deg /step and a 10TPI screw. This adds up to about 0,0127Inches per step. Any more than that and you'll have to go microstepping or a nice little gear. ![]() Henrik |
#11
| Bigger is not necessarily better. My machine has Xylotex 425 oz/in NEMA23 steppers. The Xylotex 269 oz/in NEMA23 steppers don't have the midband resonance issues that the 425 oz/in steppers have. The 425 oz/in steppers have roughly the same torque at full speed as the 269 oz/in steppers if I remember this correctly. With a 1/2-10 1 start acme lead screw the 269oz/in stepper seems to be faster and less problematic. The 425 oz/in steppers have more low speed torque for driving 5 start acme screws though. CarveOne
| Tags |
| dremel 300, hobbycnc pro, mini router, widgitmaster |
| Newbie- Any info about WidgitMaster? | efimius | Want To Buy...Need help! | 8 | 08-07-2008 10:16 AM |
| How do you do it? Any ideas, the WidgitMaster needs help! | widgitmaster | Mechanical Calculations/Engineering Design | 13 | 04-26-2006 04:30 PM |
