Old 09-10-2008, 04:31 AM
Blacksunshine is on a distinguished road
MDF cnc-vs- florida weather
how well willl a mdf table hold up to the humidity of florida's climat in a garage?
how long can I go on x or y before I get some kind of sag?
Old 09-10-2008, 05:02 AM
LeeWay's Avatar
LeeWay is on a distinguished road
The cost and flatness of MDF is generally why I think people use it the most. I tried some for tooling plates and even the first sacrificial table on my router. It did not last very long. It's flatness and cost had completed reversed itself due to swelling and the remilling flat often. This after a coupe weeks in South Alabama.
I made no effort to seal it though. Sealing it will help, but again, there goes cost in time and materials. Baltic birch would likely be the best choice in sheet goods. I use a marine plastic called Star board for my table now. Rather than using baltic birch, I just use some cabinet grade plywood now for my tooling plate and jigs. It stays flat after the first leveling run. I have been able to use the same one for a couple years. I do replace them once they start showing any sign of warping though. 2 years is much better than 2 weeks.
Lee
Old 09-10-2008, 08:06 AM
ger21's Avatar
When you mill off one side of the MDF, the tension in the sheet will cause it to warp immediately. To use MDF as a spoilboard, it needs to be securely attached to the table so it's not allowed to warp.
Old 09-10-2008, 08:42 AM
wcarrothers1 is on a distinguished road
I do 2 sheets of MFD. The first sheet is bolted down and milled flat then second sheet is bolted through the first to the table. Thus in theory when I'm done with the top one I can swap it for a new sheet. Long as you can live with the flatness over the piece within the tollerance of the second sheet it self. I have (2x2"square steel) support every 18" I think and between them I have welded in super strut support for the board
Seems to stay pretty darn flat. Course I'm in Michigan.
b.
Old 09-10-2008, 09:06 AM
GaryV1959 is on a distinguished road
I built a router out of MDF and I live in Florida , I sealed the whole machine with a clear sealer , but my opinion is that there is too much flex in a MDF router for any type of close work, on a larger mill. My mill has a cutting area of 16" x 26" with 4" on the z..
I am getting ready to build a new one out of metal because now at least I have an idea of what I want and a little more knowledge of tha machine I will be using 2" square tubing and linear rails that I have been slowly picking up on ebay for the new build.
And like Gerry says afer you mill or cut the top finish off of the MDF it does tend to want to warp because the moister gets into the unfinished side ..
My 2 cents
Gary
Old 09-10-2008, 10:24 AM
ger21's Avatar
Actually, that's not what I meant. MDF has internal stresses. If you take a new piece of MDF, and cut 1/16" off one face, it will warp instantly due to the stresses in the board, not from moisture. Moisture will just make it warp more over time.
Back to the original question, seal it and paint it with an oil based primer and you should have no problems at all. Just paint it as soon as possible.
Looking For A Job- looking for job in florida rtm74 Employment Opportunity 2 02-23-2008 10:34 AM
Weather Channel Founder: Global Warming ‘Greatest Scam in History’ dynosor Environmental & Alternate Energy 28 01-11-2008 09:22 AM
Bad Weather Shut Down johnd Mach Software (ArtSoft software) 2 06-05-2007 09:32 AM
Anybody In Florida?? $$$ pike88 CNCzone Club House 1 06-02-2007 11:34 PM
Machining in Cold Weather Sprew General Metal Working Machines 10 01-29-2006 10:10 PM
