Old 09-08-2008, 01:40 PM
*Registered*
ZigMan is on a distinguished road
EPDM foam cord gasket
Everyone that has dealings with vacuum tables is talking about EPDM foam cord gasket but no one has mentioned it where to get the stuff. I can find plenty of weatherstripping and most of it is not completely round. It always has a flat side that is designed to go against a door/window frame.
Is there anything else that can be used for a vacuum table with routed grid pattern channels.
Old 09-08-2008, 02:20 PM
ger21's Avatar
www.allstaradhesives.com
Old 09-09-2008, 08:47 PM
*Registered*
Thanks Gerry, and for your effort.
I did contact the joint that sells the stuff and they acted like they own the universe. A $100 for a small roll of 1/4" EPDM pipe, PLEASE. Just for comparison: a 10' wide X 50' long roll of 3/32' EPDM sells for $180 locally.
Is there anyone else but these resellers? Who makes the stuff so that I can sell it at $50 a roll; and I would still feel guilty about it.
Old 09-10-2008, 06:08 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Can you DIY it? You know, like make your own O-Ring? Yes - time is money - but there ought to be a trade-off there. Making O-rings and gaskets is not that hard - and you'd have stock on hand for the next! I had to make gaskets for 12 waterproof hatches/ports - now they're working like they ought too.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 09-10-2008, 06:34 AM
blackbeard52 is on a distinguished road
www.mcmaster.com 100 ft EPDM cord in
1/8" 8605K41 $12.82
1/4" 8605K42 $19.60
3/8" 8605K43 $28.55
1/2" 8605K44 $36.98
Happy days!!!!!
Bob
Old 09-10-2008, 10:33 AM
ger21's Avatar
The flat material is a lot cheaper than the round, I think. ~$75 worth of material lasts us several years in a commercial shop where our machine is running all day every day.
You can get self adhesive for much cheaper as well.
http://www.veneersupplies.com/defaul...0fb212c897ae2a
Old 09-10-2008, 10:58 AM
High Seas's Avatar
Gold Member
Good Job Bob! - all I found was the flats! DOOH! (that hurt)
Old 09-10-2008, 03:33 PM
tkran is on a distinguished road
Red face gasket material
you can purchase the gasket material thru companies like biesse or vacuumpods.com
Old 09-10-2008, 09:37 PM
*Registered*
Jim
Jim I know where you is coming from and the whole process and all I'm saying is that some business think that if you spend $5k on a table they can keep on buttering you up. If I wanted to chase that I would let my secretary do this forum.
Take care and stay with luck on your side.
Gary
Old 09-10-2008, 11:22 PM
*Registered*
I was in the glass industry for 30+ years and I know a flat gasket upside down and how to stop a 200 mph blowing rain from coming in on any high rise building so flat stuff is no problem.
It takes a thousand bucks to fab a extrusion die for this stuff and then you order it by 500lbs worth of material to be extruded for a minimum order. 500lbs of foam EPDM is a million miles of 1/4" tubing.
Someone is milking someone here and as long as they stay still, they will be milked dry.
I just need a gasket, not a Ferrari. Bob seems to be on the $.
And after all, should not there be a separate section just for vacuum table in this forum since everyone uses them? It could be broken down to tables, pumps, gaskets, and applications. If there is a separate forum for cnc toy routers, the toothpick stuff, why not for a tool that is implemented by many more applications.
Thanks and take care,
Gary
Gasket Cutting tpmx57 Printing, Scanners, Vinyl cutting and Plotters 4 03-03-2012 03:19 AM
rubber cord for vacuum table diecutter DIY-CNC Router Table Machines 3 02-17-2008 04:19 PM
IH Gasket Repair help mattinaustin Industrial Hobbies (Support forum) 67 07-26-2007 08:40 PM
gasket help santiago lisboa Digitizing and Laser Digitizing 3 02-13-2007 02:27 PM
Extension Cord dneisler Welding, Brazing, Soldering, Sealing 4 01-13-2006 07:29 PM
