Old 10-12-2004, 06:50 PM
CNC Darren is on a distinguished road
cutting text with a router
hey guys, As my machine get closer to the almost but never done phase I have a question about cutting text into a a piece of wood. Kinda like a sign with the letters cut into the wood, what software are you guys using? After tweaking my machine I would like to try this.
Darren
Old 10-12-2004, 06:56 PM
Aksess's Avatar
Aksess is on a distinguished road
i use deskengrave and best of all it is free from http://deskam.com/deskengrave.html
Old 10-12-2004, 10:34 PM
thanks!! I tried it but Mach2 didnt seem to like it but i will play with it
Old 10-13-2004, 07:41 PM
A. Shuford is on a distinguished road
i JUST GOT MY ROUTER WORKNG TODAY AND TRIED THE DESKENGRAVE ON MY MACH2 AND IT SEEMS TO WORK. BOY I AM HAVING A NEW EXPERIENCE WITH THIS PROGRAM. I OWN A TORCHMATE CNC PLASMA CUTTER AND IT WAS EASY COMPARED TO MACH2.
Old 10-13-2004, 08:07 PM
I know what you mean but I have been using the demo version of mach2 for about 2 weeks and have gotten use to it, i still dont know it all but i'm getting there.
Old 10-13-2004, 09:43 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Just a quick question [or 2 ~3, if I may]
- How are you cutting the text? (In MACH2):
1. Importing an image? I've done some neat house numbers that way, or
2. Using the "Write Wizzard"? I haven't found much use for it yet.
DeskEngrave seems to be easy to work with - I found I had to "fiddle" a bit to get the size lettering then moved back to MACH2 (for the house numbers in 1 above). Jim
Old 10-13-2004, 11:09 PM
I was making a DXF in DeskEngrave, importing it into sheetcam (wich i really like) so I can set the cutter right/left compensation and make the gcode. Then load the gcode in Mach2, so far this has worked the best.
Old 10-14-2004, 05:04 AM
One thing that I am having to figure out is how to import a DXF File into the lower left corner of the X & Y axis. If it is done in Autocad it seems to be relative to where it is placed in Autocad. If the file is done in Corel Draw, this does not seem to hold true.
single line fonts? balsaman General CAM Discussion 12 02-18-2006 11:51 AM
DXF export from Corel - Text cutting maxxgraphix G-Code Programing 3 03-23-2005 09:12 PM
large 4x8 router for cutting foam boat plugs waterboy DIY-CNC Router Table Machines 15 02-09-2005 09:59 AM
CNC router deflection calcs and cutting loads? Linus DIY-CNC Router Table Machines 1 09-10-2004 10:08 AM
CNC Router cutting Aluminum 2Gs DIY-CNC Router Table Machines 7 08-09-2004 08:21 AM
