on the c11g board I get all the lights for x and y but only 1 light for z.. I checked the voltage for the board and I get a clean 5v. All of the e stop and limits are lit. when I power up the drives My geckos come alive and I get good motor lockup. In mach3 it shows in jog mode that the steppers should be moving. Not sure what to do or check.
__________________ If you have and don't use it, you still have it. |
| First of all. Is you ouput led on the C11G lit? If not, try to set the charge pump jumper to disable. If the output led is lit, and MACH showing that the axis should be moving, and you have "holding torque" on the motors. Make sure that you have a wire between the "common" port on the Gecko and the common port on your C11G. I.E If you have setup mach to ouput X-movement on pin 11, you will a connector next to it that is marked "+5v" (If I remember it right). You connect the common port on the Gecko to that one and make sure that the jumper saying +5V or common is set to common. Hope this helps. If I undestood you right I had the exact same problem when I first wired my setup. |
| C11G, Gecko 203v and Mach 3...connect what where? | teamtexas | Gecko Drives | 16 | 12-03-2009 09:53 PM |
| Need Help!- WTF C11G Gecko 203V | georgeburns | DIY-CNC Router Table Machines | 17 | 06-05-2008 10:57 AM |
| Relé interfase C11G | fenixes | Spanish CNCzone | 1 | 05-16-2008 12:29 AM |
| C11G BOB and KBIC controller | xkbal | General Electronics Discussion | 3 | 10-23-2007 08:49 AM |
| Gecko Cnc4pc Wiring Diagram | mlaws1172 | CNC Plasma and Waterjet Machines | 0 | 09-14-2005 06:14 PM |
