#13
| Thank You very much for the information. I am going to check it out. Thanks again.
#14
| Those are great web sites, I want to thank you for the info. I am sure I will have more questions later. I am definitly going to build a cnc router.
#16
| I took advantage of J.C.K's hard work. They are rollerblade bearings running on gas pipe. Very affordable! Oh and someone asked what controller Fet3/crusier package from stepper world I've got to figure a way to get more speed from this sytem. Still not shure exactly how big my cutting area is. I was shooting for 2' x 4' It takes so long to move around at 7.5 ipm I havn't tested/used the whole area yet. |
#17
| One way to get more speed is to use higher voltage and different resistors. Another is lead screws with less pitch. I use the FET3 and get 40+ inches per minute on 1/2-10 acme rod and 27 volts. What pitch screws? What voltage motors? What voltage powersupply? Another way to get more speed is a chopper controller such as the xylotec. Eric
__________________ I wish it wouldn't crash. |
#19
| Joe, I'm using 4v motors right now. when I was running them on 12v the best speed that I could get was about 20" per minute using 5/16 18tpi threaded rod. With the same controller/motor setup and bumping a 24v power supply i can jog at over 40" per minute now. With 1/2 10 turn acme rod I could probably get as high as 60" - 70" Seems like I read somewhere (Maybe Camtronics' site.. I dunno) that best motor performance is with a minimum of 4x the motors spec'd voltage. FWIW I was really impressed at what upgrading the power supply did for me. |
#21
Thanks |
| RFQ For a Mountain Bike part | Bender | Employment Opportunity | 17 | 08-18-2005 01:38 AM |
| Problem machining accurate size part on my Bridgeport CNC conversion | fastturbovet | General Metal Working Machines | 5 | 05-24-2005 12:01 AM |
| Machined Aluminum Part Needed | Philip | Employment Opportunity | 2 | 03-13-2005 03:14 PM |
| How to copy existing part to make a mold? | dbassett74 | Moldmaking | 30 | 11-08-2004 07:20 PM |
| Found a Radio Shack part for Molex & Powermax ll connections | yorttroy | Xylotex | 0 | 07-05-2004 01:03 AM |
