Old 08-30-2008, 10:56 AM
lsteele is on a distinguished road
Compensating for non-perpendicular axis
Hello,
I've built myself a wood-constructed (MDF) router, loosely based on designs at buildyourcnc.com, but with quite a lot of reinforcement in the form of right angled bracing of the gantry and a much sturdier table. Much to my surprise it works quite well, and I've had some success cutting pine, mdf and even some aluminium. However I have one major problem which is that the y axis, which has an effective working area of ~290mm, is not entirely perpendicular to the x-axis. Between 0mm and 290mm on the y axis there's a deflection of around 1.25mm.
I want to redesign the gantry and y-axis anyway to solve other problems with rigidity, and the obviously would like to construct the parts on the router. But I don't want the accuracy to be undermined by this problem. Is there a way I can correct this problem in software - i.e. have the software operate the machine to compensate for the non-perpendicular axis? I'm using mach3 and solidworks. I have cambam, and have access to solidcam, though this is somewhat inconvenient as it involves travelling to a friend's place.
Any suggestions/input are gratefully received. If my description of the problem doesn't make sense please let me know and I'll try to better describe it!
Thanks,
Luke Steele
Old 08-30-2008, 11:36 AM
ger21's Avatar
Try this. In Mach3, go to the Function Cfg menu, and choose formulas. Check the box to enable formulas, and change the f(x)= to x+y*(1.25/290)
As the Y axis moves towards 290mm, the X should adjust by 1.25 when Y gets to 290. I did a quick test in my Demo install with no machine, and when I typed G1 Y50 in MDI, the X axis moved along with the Y axis.
Do a lot of testing to make sure it works correctly, as I can't confirm that it will work for all situations, but it's worth a try.
Old 08-30-2008, 11:41 AM
ger21's Avatar
Be aware that if you try this that the X axis DRO will display the actual value plus the compensated amount. So if you're Y axis is at 290, and you do a G1 X0, the X DRO will display 1.25, not 0.
Old 09-07-2008, 03:29 PM
Thanks for this, it seems to be working great. My parts are visibly squarer than before! Now to build a router that doesn't require this sort of fix...
Luke
Get Perpendicular Herbertkabi General Metal Working Machines 2 07-12-2008 08:41 AM
How to make axles nicely perpendicular? Witsenburg Mach Mill 10 10-02-2007 09:46 AM
Scraping perpendicular, parallel, and coplanar surfaces Builder4wd General Metalwork Discussion 24 04-12-2007 05:17 AM
Compensating for ball screw lead error? Noah General Metal Working Machines 2 08-12-2004 08:51 PM
Compensating after stopping a move wjbzone TurboCNC 1 05-18-2003 10:45 AM
