Old 08-29-2008, 08:05 PM
jaru-eri is on a distinguished road
Which cables/plugs can be used for steppers?
Where can I find inexpensive cables and plugs for my steppers. Can 6 pins firewire cables be used or will they be to weak for the currents?
Any suggestions?
Old 08-29-2008, 08:54 PM
YZF YZF is offline
YZF is on a distinguished road
I believe a firewire cable would probably have too thin conductors for your average stepper motor. The wire gauge determines the current carrying capability, e.g a quick link I Googled:
http://www.powerstream.com/Wire_Size.htm
As for connectors D-sub connectors (such as the one used for the serial or parellel port) can work well, I belive they're usually rated around 5A per pin. Molex mini-fit are another type of low cost connector that should work well.
Try your local electronics store? I see you are in Norway so I'm not sure what's out there. I'm sure there are a few companies who sell out of catalogs (RS electronics?).
There are a lot of options in the US but it probably wouldn't make sense for you...
Old 08-29-2008, 08:58 PM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Several choices for you to choose from.
http://www.action-electronics.com/ampcpc.htm
Old 08-30-2008, 06:56 AM
Richster is on a distinguished road
I used Starquad mic cable. The conductors aren't particularly heavy duty, but the cable is intentionally very flexible therefore well suited to repeated stressing on a CNC machine. Starquad had 4 conductors and a shield (which I didn't use in the end), and is made by Van Damme. As for plugs, I didn't bother since my machine is self contained and it's possible to damage the driver board if wires are accidently disconnected. However, anything which can handle your current levels would be suitable. Again from the audio world, XLR-type connectors could be good since they have locking latches.
Old 08-30-2008, 10:20 AM
langwadt is on a distinguished road
something like this? http://www.futurlec.com/XLR-5Pin.shtml
locking latch and that super neutric strain relief
Old 08-30-2008, 11:28 AM
Yup, something just like that! The most common type have 3 pins only, but like the ones you have found, they are available with more.
3phase plugs and sockets brianCAD2 General Electronics Discussion 0 11-19-2007 03:53 PM
THK rail plugs walter Linear and Rotary Motion 2 06-23-2007 12:53 PM
brz bearing w/graphite plugs rubino2112 General Material Machining Solutions 2 11-26-2006 12:52 PM
rail plugs mechanicer DIY-CNC Router Table Machines 0 01-23-2006 12:12 PM
Motor Connector Plugs rcazwillis Xylotex 5 05-11-2005 07:30 PM
