Old 08-29-2008, 06:32 AM
HankMcSpank is on a distinguished road
Poor mans XY table rails - would something like this be viable?
I'm forever trying to come up with ideas for cheap parts, I can source these quite cheaply....
I was thinking certainly for the Z axis it should be ok (obviously removing the handle/arm & also stripping the rods & support from the base), but what about two for the X axis & two for the Y axis?
I seek a cheap desktop CNC with a movement of about 12" in the X & Y axis.
I guess it depends on how much 'play' they have (can't say - not seen one in the flesh), but I could possibly negate this by use of a custom arm with a roller skate bearing on it to press up against the rail.
Old 08-29-2008, 08:12 AM
ger21's Avatar
If they have any play in them, they'll probably bind, and you'll probably find that they flex quite a bit when used on a machine.
Old 08-29-2008, 08:50 AM
So how about a leg (with a roller skate bearing at the foot) attached underneath the middle section....this should help eliminate flexing & therefore binding?
Old 08-30-2008, 08:14 PM
budP's Avatar
budP is on a distinguished road
One of the most important parts of one of these machines are the rails that the axis rides on, this is not a part to cheap out on. If they flex the machine will not work to any kind of accuracy.
budP
High Speed Machining viable for DIY?? scavenger Open Source CNC Machine Designs 17 10-11-2007 07:46 AM
Poor Man's Cutter Table vladdy Plasma, EDM and other similar machine Project Log 5 08-19-2007 01:48 AM
poor mans book dragons_fire Mini Lathe 3 01-21-2007 07:17 AM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 02:21 PM
Poor Mans Autocad solid converter CAMmando Mastercam 2 07-17-2003 08:10 AM
