Old 08-27-2008, 12:33 PM
javafiend is on a distinguished road
salvaged stepper motors
I'm building my first benchtop CNC based off of this one on instructables. I've been tearing apart every secondhand printer I can get my hands on to get the stepper motors. My question is, do they need to be identical for my x, y, and z axis?
Old 08-27-2008, 02:10 PM
Hirudin's Avatar
Hirudin is on a distinguished road
I'm also a beginner, so take this with a grain of salt...
It's OK if the motors are different. I would imagine you'll want to put the strongest on the X (the axis with the most weight), second strongest on the Y, and the last one on the Z.
I'd guess it would be preferable for the steps per inch/mm to be the same for the X and Y at least. So assuming the screws on the X and Y are the same you probably wont want to mix motors with different amounts of steps per revolution.
Old 08-27-2008, 03:35 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
javafriend - don't overlook the other good stuff in those printers - the rails and brass bearings that the printhead rides on! You get several sets of those and -- instant rails for the axis.
If tempted to use a belt drive system - those bits are there too.
BTW welcome to the CNCZone!
I'll go look for some pics of what I mean....
First one is an example of printheads salvaged and mounted to make a mini-mount for a Z axis.
The second is a draft of a vinyl cutter using bits and pieces from printers - track feeds etc.
You are only limited by your imagination -- well, and the size of the printers too
Jim
ID:	65569   Click image for larger version
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 08-27-2008, 04:46 PM
CanSir's Avatar
CanSir is on a distinguished road
Mixing motors with different resolutions (steps per revolution) isn't a problem because the controlling software (EMC2, Mach3) can easily be adjusted for that. If you get lower resolution motors (ie: 3.6 degree per step) then you can improve your machines final resolution by half-stepping them and/or coupling them to slower screws (ie: 10tpi single start screw instead of 10tpi two start screw). You lose top end speed, but gain precision.
Power requirements can be an issue though. I prefer to have all the motors matching so I can swap things around and not have to remember to adjust POTs or change power resistors before turning things back on.
Long before I got into CNC, I remember letting dozens of those really old, giant dot matrix printers slip through my fingers. I can only imagine how hefty those steppers must have been!
Good luck!
- Dean
Old 08-28-2008, 09:53 AM
@ High Seas: I've been saving nearly every useful part - motors, electronics, gears, and the rods. I seem to have missed the boat on the print carriage and other structural materials, though. Guess it's time to get bigger bins to start holding those too.
@CanSir: Thanks for the input on stepper control with different size motors. I was afraid I would be out of luck.
Another question now, how do you go about calibrating your axis? Is this something done through software? I will be using a Linux system, most likely an Ubuntu variety.
Old 08-29-2008, 04:16 PM
Hirudin's Avatar
Here's another thread with some more discussion on this subject...
http://www.cnczone.com/forums/showthread.php?t=35382
Old 08-30-2008, 06:25 AM
CarveOne is on a distinguished road
Yes, calibration is done in software settings. You move it some distance of travel and measure it to confirm that the distance moved is correct. EMC2 requires Ubuntu 8.04 currently.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
Q on stepper motors wood_Workur Benchtop Machines 4 10-05-2006 03:05 AM
Stepper Motors OG Style Stepper Motors and Drives 0 08-25-2006 03:38 PM
Salvaged Transformer from TV. Need help to use for CNC! radicooldude General Electronics Discussion 8 04-30-2006 05:41 PM
