Old 10-08-2004, 01:02 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
Need pulley advice for my steppers
Hey guys,
I've recently been thinking about what I'm goin to do as far a hooking up the steppers on my DIY router. (There is a link to it in my signature below.)
Anyhow, I pulled the steppers out of some old HP LaserJet III printers. I've read on the forums here that they should be 100oz steppers. They have spiraled gears on the drive ends. I'm using 1/2inch 10TPI Acme thread from Enco for the lead screws.
I'm not too concerned about the speed of the machine as I am about its accuracy and ability to not miss any steps. I'd like to setup a 2:1 reduction for all 3 axis'
Do you guys think I will be able to direct drive the lead screws? Again, pics and info are in my project thread.
If needed, can you guys recommend some pulleys and belts. They will need to be 1/4 inch for the inner diameter of the pulleys, and use setscrews.
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Stepper Math questions... Aegeon Mechanical Calculations/Engineering Design 2 04-28-2005 10:22 AM
Just found some steppers! chuckknigh DIY-CNC Router Table Machines 5 08-14-2004 07:32 PM
Choosing Steppers RXTurbo General Metal Working Machines 3 06-17-2004 11:21 PM
steppers and current ullbergm General Electronics Discussion 0 01-29-2004 03:24 PM
Have almost all my parts (pics), need servo advice Darren_T DIY-CNC Router Table Machines 27 01-06-2004 08:20 AM
