I have some THK bearings/carriages. They are medium size and large size (4", 6" long). When I bought them they were covered with what looked like Cosmoline. It is a very thick gooey type stuff that is tan and opaque. When I put the bearing on the rails to test them the carriages moved slowly because of the grease. So now I'm removing that grease. Questions: 1. Is it possible I'm removing the kind of grease that is supposed to be on the bearings? (i.e. Not Cosmoline but bearing grease?) 2. What kind of grease do you use on your THK bearings? 3. How much grease is supposed to be in there? 4. It looks like there is a trough between the ball bearing races where grease can sit (Top part carriage between the races.) Is that space supposed to be filled with thick grease? Any help appreciated.................Sam |
| hmmm ... I've got some bearings like that too and have thought of putting in a "lighter grease. I'm not ready to use them yet so I've had that on the back burner. But, as you say, they sure do seem to fight movement..not very fluid at all. John |
| I have come to the conclusion that I have removed the proper grease from 2 of my THK bearings. LOL. That is not Cosmoline (A rust preventative grease used in shipping, like what firearms come packed in.) I thought is was Cosmoline because the stuff was all over everything like it was shipped that way on purpose to prevent rust, not! So, clean the outside of your carriages and rails but don't remove the grease inside the carriage at all. That is good grease if it doesn't look dirty. Besides adding some grease to the 2 carriages I "cleaned" I also want to be able to lightly wipe some clean grease now and then on the rails. ![]() Recommended Grease: ---------------------- 1. AFA Grease (THK) 2. NBU15 (NOK Klüba) 3. Multemp (Kyodo Yushi) or equivalent Update: I just bought some THK AFA grease for $15 (including shipping) for 70 grams at the THK site. That's only about 3 Oz. If that isn't enough I'll start using bulk lithium based machine grease from Northern Tool at around $2 for 14 oz ( Lithium Grease at Northern ,"Fits most grease guns. Ideal for lubricating and protecting bearings, cams and other sliding elements.") Last edited by samualt; 10-07-2004 at 07:12 PM. |
| Our router at work doesn't use grease. It has oil lines into the carriages and is oiled automatically at fixed running time intervals. It uses a light to medium weight oil.
| I run em dry because I can't imagine the dust and grease "mixture" being a good thing. Without grease the dust doesn't stick. I have no idea if I am ruining the bearings, but since I am running at 10% of thier rated load, I am sure they will be fine. When I was a kid I used to clean the skate board bearings in gasoline. They were open ball bearings and they would run fine in the dirt as long as you did not oil them. If you oiled them they ran in a gritty soup. I have not noticed any wear so far. Eric
__________________ I wish it wouldn't crash. |
| I use a dry PTFE spray lubricant on mine. Dries quickly so the dust doesn't stick. I don't know if it's the best thing to do, but it's working so far. My machine prolly won't be used enough to worry about wear. |
#10
| The INA rep was just here, he says our recommendation of EP2 white lithium grease about once a week is good for sawdust. THK type bearings usually have very good wipers but if you don't use rail plugs you'll still get sawdust in the bearings. Greasing them regularly should purge contamination, just add grease until you see it squeezing out through the seals. A note on synthetic grease- If you change back to regular grease be sure to clean out all of the synthetic or you'll probably end up with a chemical reaction and some stuff that doesn't look like grease anymore. |
#12
| Alvania #2 (Shell) is a common grease used in linear guides with rolling element balls. Sort of a milky/yellowish white grease. A 'lighter' grease (cream colored) with less viscous drag can be had via the use of Beacon 325 (Exxon I think). Although it is rated as NLGI #2 it is a bit "runny" and is probably a NLGI 1-1.5 viscosity rating. If you run them "dry", you will probably see more instances of wear, especially if you oscillate back and forth a lot. Skate bearings can be run dry as they are essentially "throw aways". You simply can't compare skate bearing use to linear guide use. Synthetics: at room temp, these really don't buy you that much - especially at the price. These REALLY shine at high and low temps. For room temps, a typical non-synthetic is QUITE adequate. Since debris contamination is the most common cause of grease failures (not temperatures which is where synthetics would help), the use of a reasonably priced mineral based grease is perfectly adequate, especially if you purge out the debris via regular regreasing. However, running linear guides dry is not especially a wise thing to do. |
| Bearing Grease | georgebarr | DIY-CNC Router Table Machines | 1 | 06-06-2005 04:07 PM |
| How close can I space THK rails? | bgolash | DIY-CNC Router Table Machines | 7 | 12-30-2004 11:13 PM |
| Wrong THK rail - Help! | samualt | DIY-CNC Router Table Machines | 10 | 07-17-2004 01:26 PM |
| grease for bearings | georgebarr | General Metal Working Machines | 5 | 02-16-2004 08:54 AM |
| THK model number question | Darren_T | DIY-CNC Router Table Machines | 3 | 10-15-2003 07:33 PM |
