Old 08-17-2008, 02:14 PM
bedo is on a distinguished road
Looking for AC universal motor driver circuit scheme
ciao to all members !
for my hexapod cnc I'm looking for a circuit schematic to control speed
and possibly direction of an AC ( 220V ) universal motor.
At the moment my plans for this part are a small pic that works "stand alone"
and receive speed and direction as digital data from the main data bus and
control the motor speed keeping it to the programmed value with feedback
from sensor attached to the motor ( hall or opto ).
I have no problem writing the pic code and all the board design, I just need
the hi-voltage "interface" to the motor and how to drive it with the pic.
I have almost no knowlogde and experience with triacs and scr and I do
not want to "test & trial" with 220V....
So any feedback is welcome,
ciao, Bedo.
Old 08-17-2008, 02:40 PM
Al_The_Man's Avatar
I have schematic of a treadmill controller that was based around the motorola IC in the PDF in post #4 of this link.
http://www.cnczone.com/forums/showth...t=tpa+motorola
The TM controller uses a simple (~10 pulse/rev) magnetic PU for rpm control with triac control.
I will see if I can dig the TM schematic out, I am using one on a Band saw motor conversion.
Also see this link http://www.littelfuse.com/data/en/Ap...tes/AN1003.pdf
Old 08-17-2008, 03:33 PM
Al_The_Man's Avatar
BTW, if you want to reverse a Universal motor, it gets tricky as you have to bring the field winding terminations out in order to reverse them with respect to the armature, (they are both in series).
Easy to build CNC Mill Stepper Motor and Driver circuit Tom McWire Open Source Controller Boards 20 03-31-2010 10:09 AM
stepper driver circuit.. comments? integerspin Stepper Motors and Drives 0 09-21-2007 10:27 PM
dc series universal motor jed102 Servo Motors and Drives 6 05-02-2007 09:09 PM
RQ: Bipolar stepper motor driver circuit elektronchika Stepper Motors and Drives 2 12-21-2005 05:29 PM
