Old 08-12-2008, 09:21 AM
mrdovey is on a distinguished road
Finished building 3½-axis router
I've posted photos of my first 3½-axis router at http://www.iedu.com/DeSoto/Projects/JBot/ - it's intended for use as a programmable joinery machine. Enjoy!
Morris Dovey
Old 08-12-2008, 06:08 PM
CarveOne is on a distinguished road
The tilting router idea is pretty cool. You just need another stepper to tilt it via computer control. Never know when you might need to demonstrate how to make sine wave shaped biscuit slots or some such neat trick.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 08-12-2008, 06:59 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
Nice one. I didn't have time to look through properly right now. Was that a HobbyCNC board?
Old 08-12-2008, 08:01 PM
CarveOne...
Thanks. Originally, all I wanted were vertical and horizontal spindle orientations, with nothing in-between, for some specific joinery tasks. If I do a redesign, I'll probably tilt the entire z-axis so that I can plunge/drill at an angle - and at that point another stepper to control tilt would, indeed, make sense.
thkoutsidethebox...
Thanks for the kind words. You have a good eye - it's a HobbyCNC 4-axis kit with a bit of surgery done to the board to use the same step/direction signals to control two driver circuits (one for each of the x-axis steppers). It's worth mentioning that the HobbyCNC board and steppers have worked without problem from the very beginning.
Morris Dovey
First router finished EL34 DIY-CNC Router Table Machines 3 07-29-2007 10:09 PM
New CNC drill I'm building; just about finished Stevie Vertical Mill, Lathe Project Log 41 05-13-2007 06:35 PM
Finished building, need help using. thesaent14 DIY-CNC Router Table Machines 2 03-11-2007 09:18 PM
Building a 5-AXIS Router Cnc Wana bee General Metal Working Machines 0 06-05-2005 08:19 AM
my second router just finished trent2530 DIY-CNC Router Table Machines 7 04-20-2004 10:55 PM
