Old 10-03-2004, 07:32 PM
mjp mjp is offline
mjp is on a distinguished road
CNC Kits
Hello guys I would like some advice and it seems this is the place.
I have and love my Commercial CNC Router and would like to build a smaller one.
I need to know if there is a good source for the parts and the electronic parts.
I would like to run it with HPGL rather than G-Code.
Mark
Old 10-04-2004, 09:55 AM
jcc3inc is on a distinguished road
Mark:
Whose CNC controller are you using? I believe that MachI, II can use HPGL inputs. If not, it is possible to make an HPG-to_Gcode converter to make the G Code machine which you now have work OK.
Regards,
Jack C.
Old 10-04-2004, 09:59 AM
ger21's Avatar
Sheetcam can convert HPGL to G-code. http://www.sheetcam.com. I don't think any hobby (inexpensive) machine control will run a machine directly from HPGL.
Old 10-04-2004, 07:34 PM
mjp mjp is offline
Better des
Right now I have a Flexicam CNC Router and run it from my Laptop.
I do not have a controller or anything else for this project that is what I am after.
I need a source for the Controller, and Steppers. The reason I would like to run it on HPGL is that my PostProcessor produces HPGL. I paid a small fortune to have the post written and would like to avoid it again.
Thanks,
Mark
www.mjpcarbon.com
Old 10-04-2004, 08:37 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Thanks,
Mark
www.mjpcarbon.com
I like the parts you make for heli's, what machine do you use to cut those carbon parts out with and how do you go about cutting them out, ie how do you hold the parts down etc?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 10-05-2004, 07:04 PM
mjp mjp is offline
My machine is a Flexicam CNC router.
The parts are cut from a sheet of Carbon Fiber,
Old 10-11-2004, 06:46 PM
boxwood is on a distinguished road
Hi all
Saw this http://www.luberth.com/cstep/ not sure how it works though. but DOS controllers tend to be reliable
Learn from the mistakes of others you can't afford to make them all yourself!
Old 10-11-2004, 06:54 PM
mjp mjp is offline
not bad
I think since I already have my CNC machine perhaps my time may be better spent making an arm to hold the Plasma torch offset from the Router table would be a good solution.
Mark
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Newbie, Which Controller (Kits) can handle big CNC accurately ? step or servo ? Calico General Electronics Discussion 3 05-28-2007 05:44 PM
CNC mini lathe kits JFettig Product Announcements & Manufacturer News 3 04-01-2005 07:32 AM
Which Drives Kits best for big wood CNC ? Calico Servo Motors and Drives 0 02-27-2005 03:19 AM
The start of a big CNC project... UKRobotics General Metal Working Machines 10 09-30-2004 05:34 PM
