Old 08-08-2008, 11:47 PM
gunlocators is on a distinguished road
Where to get Linear rails and blocks?
Where is the best place to get linear rails and blocks 48" 24" and 8 to 10" for a build I am starting. I perfer NEW not used from ebay I do not want to wind up with any play....looking for thk style
Old 08-09-2008, 05:53 AM
ger21's Avatar
http://www.automation4less.com/
http://www.automation-overstock.com/
Or McMaster Carr even, but the HiWins are a bit cheaper.
Old 08-09-2008, 07:32 AM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
Chech here... http://www.techno-isel.com/LMC/Products.htm I have some of these... Awsome.... Much better than bearing type slides.. I have hiwins too... The differance is my techno gantry can be disengauged and a light push and it'll travel the 10' easily http://www.techno-isel.com/LMC/Products/Iselrail1.htm ... My hiwins would require a constant force...
I have these on my Z http://www.techno-isel.com/LMC/Products/IselRail300.htm
Good luck
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Old 08-09-2008, 08:55 AM
LeeWay's Avatar
LeeWay is on a distinguished road
The difference is low to moderate loads for those. Still quite capable in a router I would think.
I get fair travel speeds and accuracy on my router with a heavy gantry just using roller skate bearing on some cold rolled steel.
It is a semi production machine. I run it at most a couple days a week now.
Certainly not as long lasting, accurate, smooth or rigid as linear rails, but a heckuva bunch lower cost.
I am using THK's on my newer builds though. They are nice to work with and very reliable.
I find new old stock on Ebay often. I check for specific sizes.
I bought 10 brand new trucks in one auction. I bought an actual rail from THK online, but have seen and purchased more of the same on Ebay.
It is fine if you have time to watch for what you want.
Other than that, I would go with Hiwin's. They are pretty nice too. I did get one set of those, but haven't yet put them in action.
Lee
Wanted..Rails only for THK HSR35 blocks rodjava Want To Buy...Need help! 0 01-21-2008 08:59 AM
hiwin guide blocks and rails eloid Linear and Rotary Motion 5 12-10-2007 05:46 AM
Thomson Super pillow blocks and thk rails for woodworking endgrainguy DIY-CNC Router Table Machines 2 10-23-2007 01:50 PM
What size THK/Hiwin rails and blocks? Zumba Linear and Rotary Motion 8 08-24-2006 11:10 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
