Old 10-03-2004, 02:15 PM
senor J. is on a distinguished road
question about ball screws
When speaking of ballscrews does preloaded mean it will have no backlash?
Old 10-03-2004, 02:24 PM
*Registered*
ESjaavik is on a distinguished road
Yes.
The message was too short, so this is added to make it longer.
Old 10-03-2004, 03:03 PM
Bubba's Avatar
Bubba is on a distinguished road
Only if all the other parts are also zero backlash (for instance all the bearings to hold the screw from moving axialy (sp?) )
Don't ask how I Know
Old 10-03-2004, 05:55 PM
samualt is on a distinguished road
A regular ball screw will have some backlash. This is usually brought about when you change direction and the ball bearings move from one edge of the screw threads to the other. No matter how tight that gap is there is always some movement.
A preloaded ball screw usually has (I guess) two actual ball units on it. One has bearings on one side of the screw threads and the other ball unit has bearings on the other side of the screw threads. This also means there is slightly more tension and thus torque needed to turn the ball screw. They can be adjustable and/or factory set as to the tension between the two ball units. They are also more expensive because you have a second ball unit.
Of course, you are just eliminating the backlash of the ball screw. You can still have lots of backlash in the bearings and other places.
I hope some of that makes sense. I'm still figuring it all out myself!
Old 10-04-2004, 01:58 AM
*Registered*
Preloaded ballnuts can also have only one nut.
Then the preload is made by the separate ball paths in the nut being offset. Just like 2 nuts insde one. Another approach is to use slightly oversize balls. This is more compact, as the same balls take the load regardless of direction.
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 08:27 PM
Which Ball Screws to use? Willyb Linear and Rotary Motion 4 01-19-2005 08:49 PM
Ball Screw Mounting Question. Willyb General Metal Working Machines 11 01-18-2005 12:02 PM
Ball Screws & Nut Advice coolman General Metal Working Machines 1 12-24-2004 08:29 AM
Z-Axis and Ball Screws samualt DIY-CNC Router Table Machines 15 01-10-2004 02:10 PM
