| Continued from: http://www.cnczone.com/forums/showthread.php?t=1985 Hi Graham, I though I'd better move the discussion here before we upset the moderators ![]()
The M8 x 1.25 thread and stepper motors don't make it the fastest thing in the world (~15mm/s) but over such a small bed it's not really a problem. >Have you measured the accuracy/repeatability of X and Y? No, not yet, but it's fairly good (hey, the projects in its tenth year , no need to rush )
I wouldn't have thought wear would be a huge problem at the loads you'll be running them at; A simple oil-soaked felt wiper at each end would suffice surely?
Regards, Bill |
Hi Bill, thanks for more info. I hope you can follow my reply below, the quote system doesn't work the way I expected. "Yes, the M8 threaded rod is off the shelf from CPC (although I had to order a few "lengths before I got one straight enough), the nuts are simply made from 3/4" diameter PTFE extrusion." I hadn't heard of CPC before but they look pretty useful and cheaper than RS! If the test piece mentioned below goes ok I might try buying some threaded rod from Screwfix, they have S/Steel and plated MS in 0.3 m and 1.0 m lengths. Smallest pack of 1m lengths is 5 pieces but I would have no postage if I pick it up from a trade counter. "The attached pic shows the Y axis nut with M12 nylotron(?) mounting nut. I added brass nut thinking I'd need to reduce the backlash, but the PTFE stretches around the tap as it cuts the thread, so it forms a snug fitting nut without it." I was worried about straightness mainly. I have some odd bits of threaded rod, probably rather knocked about but ok to experiment with, and metric taps so will try making a test piece lead screw and nut. "The M8 x 1.25 thread and stepper motors don't make it the fastest thing in the world (~15mm/s) but over such a small bed it's not really a problem." Speed doesn't worry me either at my proposed size of machine. ">Have you measured the accuracy/repeatability of X and Y? No, not yet, but it's fairly good (hey, the projects in its tenth year , no need to rush )"Ten years makes me feel slightly less guilty at my lack of progress. The accuracy is not too critical for my proposed use. "The steel tube in the slider will be the length of the slider minus an inch or so at the bottom (where the damper fixes), minus the fork movement." That is about how I made my estimate. I should remember the stanchion lengths as I have had these forks apart. "I wouldn't have thought wear would be a huge problem at the loads you'll be running them at; A simple oil-soaked felt wiper at each end would suffice surely?" I think I agree, fitting a second seal would be quite a challenging job. However, I like the idea of keeping swarf out of the moving parts so would keep the idea of the gaiters. I saw a professional CNC router table which had rubber gaiters to cover the horizontal axes ways. "Have a good look around the bottom triple-clamp, if they've been thumped it'll usually show there. I wouldn't worry about a little pitting." I was thinking of straightness rather than pitting but my comment applies to that too. I would do better to make sure the forks were straight before buying. I couldn't find any standard for fork stanchion straightness in my references but one of my workshop manuals refers to "stanchion maximum warpage" of 0.1 mm, less than 4 thou. Shame I don't know what warpage is. It does specify clearance between stanchion and lower leg as 0.050 mm to 0.114 mm, 2 to 4.5 thou which should do me for woodwork I guess the sensible thing to do would be to make up one axis and measure the accuracy and repeatability of that completed axis arising from the combination of tolerances and any backlash.Regards Graham Last edited by grahamweekes; 08-07-2008 at 07:54 PM. Reason: Correct omission in text |
. It's best to buy them in a pack if they're going by post; there's less chance of them getting bent in transit.
| dovetail slides | atoroguy | General Metal Working Machines | 4 | 12-13-2007 09:24 AM |
| Linear Slides | pbunnstf | DIY-CNC Router Table Machines | 3 | 07-18-2006 08:47 PM |
| Linear Slides v/s rail slides | bryanrabb | DIY-CNC Router Table Machines | 4 | 03-27-2006 08:45 PM |
| Where to buy THK slides | georgebarr | Linear and Rotary Motion | 10 | 12-13-2005 08:02 AM |
| Dovetail slides | coolman | General Metal Working Machines | 16 | 12-16-2004 05:59 PM |
