| You can use just about anything, start with a sanding sealer than a clear polyurethane.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| What kind of topcoat will you be using?
| Shellac... Yeah, definitely shellac. It'll seal things up without causing it to swell since it's alcohol based. As opposed to a water or oil based sealer. And Shellac dries in just a few minues and will accept "ANY" kind of paint very well.
__________________ Nathan |
| Yeah, like he said! Yes, I know I am repeating anoel...'cause he is right. Shellac primer is the answer. It dries in minutes so the MDF does not act like a paint sponge. It seals out moisture unlike other primers, and it takes the final coat very nicely. BIN is a brand available around here; sold as a knot and smoke sealer...careful though, not all knot sealers are shellac. Latex final coat is fine, Something semi or gloss for the final will be easier to keep clean.... leftover exterior house paint will work well too. Edit:Spell-check Last edited by sol; 10-02-2004 at 09:41 AM. |
| Xairflyer's first MDF CNC router | xairflyer | CNC Wood Router Project Log | 302 | 12-20-2011 06:37 AM |
| Caution building with MDF | DJ Morrow | Safety Zone | 16 | 01-30-2007 09:28 AM |
| MDF with Plywood | spalm | WoodWorking | 14 | 11-14-2005 06:45 PM |
| MDF Machine - Cut Aluminum? | JavaDog | DIY-CNC Router Table Machines | 7 | 11-10-2004 01:05 PM |
| MDF Finishing Question | The Wizard | DIY-CNC Router Table Machines | 3 | 10-31-2004 10:29 PM |
