Old 09-30-2004, 01:48 PM
tpaulson is on a distinguished road
Table / stand to put desktop CNC router on
What do you have your benchtop cnc routers sitting on?
I have ordered a desktop cnc router, about 28 x 28 overall dimensions and 70 pounds. It is made mainly of alluminum. I was planning on just putting it on a flat, sturdy workbench. The machinist, were I work during the day, said it should be on a 300lb "tool" granite top for flatness and stability. That seems a bit extreme to me. Supposedly, the machinist had problems with a similar router being inaccurate on a standard commercial workbench.
What do you guys think?
Have your workbenches/tables caused any problems with cnc routers?
Tim
Old 09-30-2004, 02:14 PM
buscht's Avatar
buscht is on a distinguished road
Mine is about the same size and is sitting on 1-1/2" particle board counter top supported by 2" metal legs.
I can't see any problem.
Old 09-30-2004, 04:02 PM
*Registered*
CNCPlastic is on a distinguished road
Home Depot has a great workbench they don't advertise, I found them sitting on the 3rd shelf next to the lights. Steel construction, about a 2 inch thick laminated hardwood top, 54 inches long, 2 large ball bearing slide drawers, two shelves, plus freaking large casters for $99. I bought 3 of them!
Anyone using xylotex stepper kit for a cnc plasma or router table? muleworks Xylotex 2 03-10-2006 07:52 AM
CNC Router Taper Machine hadjcues DIY-CNC Router Table Machines 8 03-23-2005 05:02 PM
Need some advice on DIY 24"x24" CNC Router Table... kanankeban DIY-CNC Router Table Machines 27 06-01-2004 06:38 AM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 11:43 AM
Cnc Router table Plans and ideas ljoe1969 DIY-CNC Router Table Machines 23 11-13-2003 08:12 AM
