Old 07-29-2008, 04:32 AM
Blacksunshine is on a distinguished road
What is a good 3d program?
Is thier a easy to learn program out thier that I can draw simple 3D shapes to cut on a cnc?
Old 07-29-2008, 08:09 AM
ger21's Avatar
Depends what you mean by simple. Alibre Xpress is free, and pretty easy to learn. You might also want to look at Silo. www.nevercenter.com
ger21's Avatar
Also, easy to learn for some may be nearly impossible to learn for others.
Old 07-29-2008, 09:02 AM
solodex2151's Avatar
solodex2151 is on a distinguished road
I only use SolidWorks myself so I really can't give you too much advise. SolidWorks is great, but expensive and more suited to complicated parts and assemblies. The learning curve is also very unforgiving. Still, you can import it into Vectric's Cut 3D.
Old 08-07-2008, 07:38 AM
Hirudin's Avatar
Hirudin is on a distinguished road
Whatever you do, download and try demos before buying.
Rhino has an excellent demo and isn't too much to buy (relative to other packages). Check out Novedge, they're selling the educational version for $145!
Old 08-07-2008, 02:57 PM
Rance's Avatar
Rance is on a distinguished road
I'm getting to really like Google SketchUp for other drawing. Is there a way to convert those drawings to g-code? Not in one step, obviously.
Rance
Old 08-08-2008, 06:08 PM
Wulffdk is on a distinguished road
Hi everybody.
I'm using Solidworks at the moment to create simpl 3D models to try the works. Is it possible to use CAMworks to create Gcode to MACH3 software? or does anyone have some ideas for CAM and machining SW?
Is it a good program??? Tompie Solidworks 23 11-02-2005 10:03 PM
Good Program Biggermens Vectric 0 09-30-2005 10:40 PM
Is it a good program? IsyCAM 3.0 CADkathy General CAM Discussion 2 12-09-2004 05:28 AM
IS Bobcad V19 a good program to start Biggermens General CAM Discussion 15 10-29-2004 09:46 PM
