Hi I have to cut a hobbycnc 305oz-unipolar stepper motor shaft in order to fit it to a K2CNC z-axis. I know I could just add lots of washers but it would be a neater and stronger job if I just cut the motor shaft to the appropriate length. I am not sure how best to do this without damaging the motor and I am looking for suggestions. |
| Use a Dremel Moto-Tool fitted with one of the thin brown cut-off wheels. Heat sink the shaft between the place that is to be cut and the stepper motor end plate with a small vise grip plier clamped lightly on the shaft. Use high RPM and cut slowly so as to not overheat the shaft excessively. I have cut off the hardened stainless jaws of a digital caliper with relative ease, so the stepper motor shaft should not pose any problem for the cut-off wheel. Just try not to bind the wheel and break it, and use eye protection in case it happens. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Thanks for the reply. I have an old milling machine and I was considering using that to clean up the end of the shaft after cutting but I don't really know whether the few end mills that I have could deal with the shaft metal. I got this mill for free and have not used it for any serious metal work and do not really know much about milling metal because I am mainly a woodworker. |
| If you can fix the Dremel Moto-Tool to the spindle on the old mill. Tape or hose clamp to a rod held in a collet etc.. You could put the stepper on the mill, shaft pointed up, connect up the stepper to its driver and get it spinning. You could then do a very neat job of cutting the shaft off, even put a little chamfer on the end. You may want to some kind of shield over the stepper around the shaft to keep the dust off it. |
| Stepper motor with 6mm shaft? | juzwuz | Stepper Motors and Drives | 6 | 03-23-2008 02:19 AM |
| Stepper motor with 6mm shaft | juzwuz | Stepper Motors and Drives | 4 | 01-16-2008 12:16 AM |
| Stepper Motor, 6mm shaft | juzwuz | Want To Buy...Need help! | 0 | 12-20-2007 03:38 PM |
| KL34H2160-62-8B stepper motor / drw dual shaft size ? | harryn | Automation Technology Products | 0 | 08-17-2007 01:51 PM |
| Dual and single shaft stepper motor differences? | Menatep | Stepper Motors and Drives | 5 | 04-09-2007 10:22 AM |
