| I use a Rigid router in my machine. Anyone have any suggestions (besides a tool changer) to manually change the bits from 1/4 to 1/8" and still maintain a good tolerance? My current method of jogging off home changing bits and the returning home to align the bit works fairly well, but I'm hoping there is a better way than eye-balling it. Thanks, Matt |
| Make a tube and plug it on one end. Have it the length you want your tool to hang out of the collet. Loosen collet nut change tools and insert tube over tool hold to the Collet and tighten. All tools will be the same length as you use them in this manner. |
If the bits are ~1" different in overall length, this most likely won't work.
| What Think and Tinker does, if you order it that way, is press on a bushing to the same height on all of them. So If I change bits as long as it's all the way up against the collet it's perfect. You could call them and see if they have any for 1/4" and how you would go about setting them. BTW the bushing is plastic. |
| Which Router bits to Use | joecnc2006 | WoodWorking | 7 | 05-06-2011 05:06 AM |
| ROUTER BITS | CABSPEC22 | WoodWorking | 7 | 01-17-2008 09:35 PM |
| Yet again about router bits. | Konstantin | WoodWorking | 5 | 12-08-2006 09:31 PM |
| CNC router Bits | marksnwv | CNC Tooling | 0 | 11-18-2006 10:48 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
