Old 07-18-2008, 03:33 PM
rmetoile's Avatar
rmetoile is on a distinguished road
NEXEN RPS linear
Hello all,
I've just seen it on the web : http://www.nexengroup.com/rps
it's seem to be very interesting for long run routers... like surf shaping machine or longboard cutting router. Does anybody has some infos about Nexen's system? That would help me to choose between using rack and pinion and ball screws or Nexen's RPS to run my 1.5meters router X-axis.
Michel
Old 07-18-2008, 05:28 PM
ger21's Avatar
There are several threads here discussing it. It's a very expensive choice.
Old 07-19-2008, 06:22 AM
rmetoile's Avatar
nexen
Gerry you're right next time I will check using the search engine if similar posts exist.
Anyhow, even if nexen's linear design seems to be very cool it is also very expensive you are right again! So I will develop my router table with long ball screws.
Consequently I have an other question :
Router table will be : length 1500 x 500 width (process length)
In this case should I use a double ball screw design (with belt and pulleys to synchronize) for X-axis?
Michel
Old 07-19-2008, 06:51 AM
ger21's Avatar
Michel
It depends on how rigid your machine is, but two screws tends to be the preferred method.
Old 07-19-2008, 05:50 PM
Cartierusm is on a distinguished road
What kind of cost are they? They are pretty cool.
Has anyone uses Linear motors, or linear steppers? Swiss Linear and Rotary Motion 24 04-11-2012 10:19 PM
Nexen Roller Pinion Drive Bobbyr70 Linear and Rotary Motion 12 06-13-2008 11:50 AM
dmu 50 evo linear pompey steve Deckel, Maho, Aciera, Abene Mills 2 01-04-2007 08:09 AM
Linear rods and linear brushings Com Linear and Rotary Motion 4 06-28-2005 05:48 AM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
