Old 09-25-2004, 03:08 PM
CNC Darren is on a distinguished road
drill rod longer than 36"? where?
does anyone know where to get drill rod in lenghts longer than 36"? I was hoping to get all my stuff from MSC since they are local here but they only carry up to 36"
Old 09-25-2004, 03:49 PM
HuFlungDung's Avatar
Moderator
That's one of life's mysteries, and also the basis why I don't believe the metric system is "natural' (Let the flames begin )
Old 09-25-2004, 07:02 PM
*Registered*
ESjaavik is on a distinguished road
@Darren: I buy drill rod in 3m lengths. I'm sure if you try someone that sell steel to the industry you can get that length or longer.
@HuFlungDung: What units do you measure current and voltage in?
I'm glad I mostly have to calculate time shorter than one second. When getting above 60 seconds, I get a feeling for how it must be to use imperial. And it's not a good feeling. But by all means stick with imperial for as long as you can. It's nice for us to be able to make things quicker.
Why do you think you were born with 10 fingers and not 4,8 or 16?
Old 09-25-2004, 09:17 PM
Gold Member
Ken_Shea is on a distinguished road
They have it in 12'
http://www.toolanddie.com/~smgr2/Mer...ory_Code=TLKDR
Removal of the drill press depth stop threaded rod devinchi Shopmaster/Shoptask 4 03-14-2010 10:10 AM
Drill Rod For Linear Ways heilcnc General Metal Working Machines 3 02-28-2005 12:41 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 10:16 AM
Drill Rod Diameter Recommendations grempel1 CNC Wire Foam Cutter Machines 6 11-19-2004 10:28 AM
Thomson vs. ground drill rod TommyB DIY-CNC Router Table Machines 10 03-21-2004 11:08 AM
