Old 07-13-2008, 09:31 AM
solodotcom is on a distinguished road
Formula for calculating step setting for Mach 3
I have set up a 3 axis controller box and am about to connect everyting to my electronics. Where can I find the formula to calculate step settings?
Old 07-13-2008, 10:17 AM
ger21's Avatar
If the machine is driven with screws, it's the motor's steps per revolution times turns per inch of the screw times steps per revolution for the drive.
Old 07-13-2008, 10:42 AM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
example:
10 micro-step drive (Gecko)
English threads, .200" per rev, 5 rev = an inch
200 step per rev motor
200 * 5 * 10 = 10000 steps
Walking is highly over-rated
Old 07-13-2008, 01:15 PM
Thanks for the help!
I think I've got it now. I looked at the specs on the keling site for the 425 oz/in stepper and it showed 1.8 degrees per step, so I'm assuming that the 200 is 360 degrees/1.8 degrees per step. My x and y are acme 8 tpi 2 start so that would be 200*4*4 for 3200 steps per inch?
Old 07-13-2008, 01:32 PM
Yes, a 1.8 deg motor has 200 steps per rev.
I'm guessing your driver is a 4 micro stepping drive?
The math is right.
Jack
Old 07-13-2008, 04:01 PM
Motors are Spinning!!
Thanks for the help. I've heard the sweet sound steppers spinning for the first time. One more quick question. How do you jog the z axis? I used up and up and down, left and right for the y and x axis. Is there a keystroke for the z?
Old 07-13-2008, 04:09 PM
Page up
page down
Or use the pop up mpg screen ( press TAB key to pop up the mpg screen )
Jack
Old 07-14-2008, 05:11 AM
Richster is on a distinguished road
You can customize all keystrokes from the setup config screens. I forget if pg up and pg dn worked for Z by default, but this is how I set mine up anyway.
There's lots of information on this, and drive setup maths, in the user manual which you should download and take the time to have a thorough read of. There's a few gotchas in there which I missed first time round!
Old 07-14-2008, 08:13 AM
Many Thanks! What a great group of folks!
I had tried page up and page down and hadn't realized that Z was actually incrementing in the screen (this is still so new for me). I did a little trouble shooting on the z axis and found that I'd crossed my power and pulse at that driver. Swapped it out and all is happy.
Old 07-14-2008, 09:35 AM
Glad to hear everything is going good for ya!
Happy machining (cheers),
Jack
  #11   Ban this user!
Old 07-18-2008, 10:25 PM
GUNSTOCK is on a distinguished road
Your math shows your microdriver is set to 1/4..make sure this is correct..Just in case test your machine..Lets say move your machine 5 inch and double check if machine moved 5inch...you can drill two point for 5 inch and then double check too..If it is not correct be sure your microdriver is set correct microstepping ...thanks..
Need Help!- Mach 3 lost is setting jfgirard16 Mach Mill 2 01-25-2008 08:22 AM
Setting Up an X3 in Mach bryanrabb Benchtop Machines 8 07-31-2007 07:48 PM
setting up Mach 2 help needed reeftoker75 DIY-CNC Router Table Machines 7 03-28-2006 08:29 PM
Setting Up Mach 2/3 SPEEDRE Mach Software (ArtSoft software) 3 09-20-2005 06:59 AM
Accel Step Rate Hz Setting Sanghera TurboCNC 3 04-30-2005 07:10 AM
