Old 07-11-2008, 11:42 AM
Todd W is on a distinguished road
vacuum table
Need help design of vacuum hold down table. This will hold a 4x8 sheet and looking to put vacuum in the middle. What type of wood, how thick or would you use inserts?
I will have a manifold down the side with 6 up tubes and T valves.
for my table
ID:	62937   Click image for larger version
ID:	62938   Click image for larger version
Vacuum table and vacuum pump garagefela DIY-CNC Router Table Machines 19 01-25-2012 10:30 AM
Vacuum Table CNCRob Work Fixtures and Hold-Down Solutions 146 04-15-2009 04:57 PM
DIY Vacuum Table Baudros DIY-CNC Router Table Machines 5 04-07-2007 12:57 AM
vacuum table dmglass General Metalwork Discussion 3 11-16-2006 05:46 AM
Vacuum table balsaman DIY-CNC Router Table Machines 11 01-05-2004 08:18 AM
