#13
| In answer to the original question - yes Prazi (Germany) still use a round bar with a flat on it for small lathes. This was a common construction for watchmaker's lathes going way back into the misty deeps of time. Not really very good, IMHO. The asymmetry of the cross-section will tend to make the bar warp during heat treat. And it would also warp during grinding if ground from a heat-treated bar, as the internal stress is relieved asymmetrically. Stick to the commercial way bar designs - they have MANY years of experience behind them! I speak as one who has been around way-grinding in the machine tool industry for a good many years. |
#14
| You're absolutly right just finished one bar and the darn thing is like a snake. I machined the flat on it and whaamo right off the mill she was bent. SOOO I think I might try another method to produce cheaper rails. I've hear of cold formed flat bar and bearings being used and this may be another alternative. I'll keep everyone posted. |
#16
| I know it's been a while since you've written this, but I was hoping you had some photos of the machine you built with the Igus W rails... Thanks, Mike...
#17
| I am just about to begin construction on my IGUS equiped router. I found out the other day that the guy I was going to get to CNC the parts for me is on vacation until August 3.... The good news is that the design is finalised, finally. I will probably abandon using IGUS slides on the Z, but I am sure they will be perfect for the x and y. I will be sure to do a build thread when the time comes. In the meantime, I am going to work on the control panel. This machine will be swank and I am excited to get it finished up. Colin |
| THK Slide pack FBW? Cheaper linear system? | InspirationTool | Linear and Rotary Motion | 1 | 05-25-2005 05:21 PM |
| T-Slot Linear Slide question | audball22386 | 80/20, TSLOTS and other Aluminum Framing Systems | 1 | 03-04-2005 01:19 AM |
| Simple linear slide design | CNCadmin | Linear and Rotary Motion | 21 | 01-19-2005 03:55 PM |
| Inexpensive Linear Slide Assemblies? | Homl | DIY-CNC Router Table Machines | 15 | 06-03-2004 01:05 AM |
| New Idea for Linear Bearings | jgro | DIY-CNC Router Table Machines | 23 | 03-27-2004 11:41 AM |
