Old 09-22-2004, 01:29 PM
CNC Darren is on a distinguished road
New to the group
Hi All
First post here, tho I have been lurking for awhile. Well I have decided to build a version of Jgro's free plans that are on here. Thanks to Jgro, very nice set of plans, and free to boot!!! Only change I think i'll make is to go with 1/2-10 ACME threaded rod instead of the 1/4-20 as on the plans. Its main purpose will be to cut out parts for model airplanes and possably some 3d engravings if I ever get that far in CAd.
For the motors/driver i'm going to go with the 3 Axis unipolar chopper system from HobbyCNC , as i think this would be the quickest way to get it up and runnning.
I Have a spare Pentium3 550Mhz computer to run it.
sound like a good start?
Darren
Old 09-22-2004, 02:18 PM
jgro's Avatar
Gold Member
jgro is on a distinguished road
Sounds good to me The only thing that I would probably do different if I were to do it again would be the table top. It will sag over time. I would get some pieces of 2x2 steel tubing and cut notches into the end plates to support them. Then use a piece of MDO (medium density overlay) plywood as the main table top and another piece of MDF as the cutting surface.
jgro
Old 09-22-2004, 03:30 PM
Sounds like a good idea to me, I had thought about making the table replaceable as a whloe. So I could have 2 tables, one for clamping down parts and the other as a vacum table. I had also though about for the non vacum table just running 1-1/4X1-1/4 aluminum angle lenghtwise under the table to strengthen it instead of the MDF framework in the drawings.
Darren
Old 09-22-2004, 03:52 PM
jgro's Avatar
Gold Member
According to a program we have at work called MDSolids, a 1-1/4 x 1-1/4 x .125 thick aluminum angle will deflect about .06 with 20 lbs on it. Steel with the same dimensions is about .02. 2x2x.125 wall will deflect about .002. Food for thought.
jgro
Old 09-22-2004, 03:54 PM
ahhh ok. guess we will go with steel then
Thanks!!
Old 09-22-2004, 07:43 PM
ger21's Avatar
Just a note. I've got some 1-1/4 x 1-1/4 x 1/4" aluminum angle. 6061-T6. It is many times stronger than the flimsy 1/8" stuff. Yet still just as easy to work with.
Group Picstep pcb buy dberndt PIC Programing / Design 84 01-11-2006 08:43 AM
New group for PicStep randyf1965 CNC Wood Router Project Log 0 04-24-2005 04:20 PM
TahlCAM's New Group Browser tahlinc Tahlcam 2 11-26-2004 10:03 AM
Student Design Group Joe CNC DIY-CNC Router Table Machines 0 10-02-2004 02:08 PM
Industrial Arts (Shop) teachers Group Grue Australia, New Zealand Club house 2 03-29-2004 06:06 AM
