Old 09-21-2004, 10:07 AM
Tabor is on a distinguished road
Work has commenced, many questions
Hey guys
I have started to build a CNC machine and have a few questions.
My machine is made out of Aluminum, and has a working area of around one A3 sheet of paper.
I have linear bearings for the X and Y axis running on 20mm High Tensile Precision Ground Bar. The Z axis is using sintered brass sleeves on 1/2 inch PG bar.
The first couple of questions have to do with the "ball screws".
Is the machine best made with the same pitch threads?
I am not using proper Ball Screws yet but have decided to use precision threaded rod with wide Brass Nuts, Two nuts on each rod with a spring to seperate them. and a housing around the two.
I am hoping this will be suitable to reduce backlash????
Any comments??
Cheers
Tabor
Old 09-21-2004, 10:42 AM
jcc3inc is on a distinguished road
Dear Sir:
Can you tell me the size of "A3" paper? Also what is a "PG" bar?
Regards,
Jack C.
Old 09-21-2004, 10:51 AM
A3 is Approx 11.5 x 16.5 inchs
PG bar is just precision Ground Round Bar.
Tabor
Old 09-21-2004, 12:46 PM
Graham S is on a distinguished road
If you use belts between the screws and motor then you can match the mechanical advantage of each. So if one has half the lead/pitch of the other you might use half the gear ratio. If you are going to run direct drive with steppers then probably best to keep X and Y pitches the same.
Graham
Questions - Micro CNC router? DarkWolf DIY-CNC Router Table Machines 36 10-22-2004 10:24 AM
Work Holding Methods InventIt DIY-CNC Router Table Machines 13 09-14-2004 04:13 AM
What is 2.5 d work Patrick2by4 DIY-CNC Router Table Machines 9 07-05-2004 12:04 PM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 07:24 PM
BPort Series I and VFD questions NeoMoses General Metal Working Machines 3 09-24-2003 11:47 AM
