Old 07-07-2008, 04:30 PM
bedo is on a distinguished road
Hexabot machine
Hi to all members !
I'm new to this forum and I'd like to present my ongoing project of an hexabot
machine. All is completely DIY by me, attached is cad design and a frame from a test cut video on a block of resin.
Machine frame is composed of two ( 3 with the base ) exagonal wood base joined by columns and stiffened by diagonal chains. I'll post some other photos soon.
Mill ( at the moment a plain drill... ) is placed on a round platform joined by six variable lenght legs with stepper motors.
Machine will be driven by selfbuilt control board that interface a standard pc to the six driver boards via RS232 and custom protocol.
Software will convert standard Gcode ( from any cam software ) to drive commands to set the correct lenghts of the legs.
Anyone interest in sharing comments and ideas is welcome !
ciao,
Bedo.
ID:	62737   Click image for larger version
Old 07-12-2008, 09:58 AM
Hexabot ball joints
It's me again, I'll post some more details for my machine :
here attached the joint shoots. There are 2 kind of homemade ball-joint : one for base attachment and one for platform attachment. The one for the base has a plate for attaching the stepper motor, while the other one has a square metal part that fits on end of leg.
These have been made using spherical ball handles I found in a furniture spare parts shop. This handles have been put inside a resin part ( bicomponent epoxy ) so that it fits exactly around the sphere, keeping it locked for just a couple of mm.
In this way I can get an inclination from vertical of about 60°.
This have been one of the hardest part to build, I made really a lot of test before reaching these results.
I think this part will be remade in metal ( if ) when the machine will be working.
ID:	62978   Click image for larger version
ID:	62979   Click image for larger version
ID:	62980   Click image for larger version
Old 07-12-2008, 10:09 AM
Hexabot legs
Here You can see one of the legs during assembly.
In "leg1" You can see the end of the fixed part of the leg. Here I fitted a round resin part with a square hole, where the other part can move without rotating.
In "leg2" the other side of the fixed part, with base for fitting the stepper motor.
In "leg3" the top of the movable part, with inside the precision screw. The round part on top of the screw keep it centered inside the square part while rotating ( otherwise I'll get weird noise when moving...).
In "leg4" the other side of the movable part, with round bae with o-ring that
exactly fits the outside tube. This part has been molded with a screw inside so I get an exact copy of the screw to drive to movement. At the base of the driving screw the joint for the stepper motor. This resin parts have been pretty hard to get them right and working.
In "leg5" the stepper motor assembled on screw and finally in "leg6" the complete assembly with the ball joints.
ID:	62982   Click image for larger version
ID:	62983   Click image for larger version
ID:	62984   Click image for larger version
ID:	62986   Click image for larger version
Old 07-12-2008, 10:21 AM
Hexabot assembly
here You can see the structure of the machine assemble as in the first cad drawing I sent.
The base are 19mm MDF which is the only material I found at a reasonable price to keep vibrations low.
The orange columns are made with standard pipes nicely cutted all at the same lenght with a precision saw. Then I filled this with cement with nuts "glued" inside, to give some weight and stiffness.
At center of the base at moment I mounted a standard clamp for some testing.
On this shoot the legs are not assembled because I'm doing some reworking at the moment but I will soon post a complete assembly.
The chains keep the structure in tension so it cannot bend while working.
Below the base, for each column, a nice stand with screw to keep the whole machine perfectly vertical.
Old 07-12-2008, 12:29 PM
greybeard's Avatar
greybeard is on a distinguished road
Hi Bedo.
Many thanks for posting your pictures with your thread.
I know very little about hexabots, though I think they are interesting because of being so different from 3-axis cnc.
Makes my brain work in a different way, which has to be good.
Given the dimensions of the one you are building, what will be the possible "angle" downwards from the top of the work piece that you will be able to reach ?
For example, will you be able to come in horizontally on the "equator" if your workpiece was a sphere ? Or even lower ?
Regards
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
Old 07-12-2008, 01:32 PM
Actual figures cannot be evaluated exactly because of odd maths behind it...
Near the origin I guess the platform can withstand angles of around 45-50°
from vertical.
This is in strict relation with the maxim angle the ball joint can do. With the
one I've built the angle is still pretty limited, mainly because the base of the joint are vertical and not oriented to the base one, and so for the opposite one. If the machine will ever work I already plan to machine better ball joint in metal with the base oriented lets say 45° so it will be able to have more travel in both direction. This is the main limit at the moment: when at origin the joint have a lot of travel in one direction and limited travel to the opposite. I don't know if its clear, its not easy to explain in words...
Other post and photos will follow in a few moments...
Old 07-12-2008, 01:40 PM
Hexabot assembly
this evening I finished assembly the legs and reassemble the movable platform, so here the photos.
As in other post here in the platform images, You can see a position near "home" position ( all legs completely retracted ). As You can see the ball joint position is already around 30° from their vertical, so possible movement will be almost 90° in one direction and only 30° in the opposite. But You must take in account that the opposite ball-joint will limit the movement on the other side, so the maximum vertical angle for the platform is limited by this at the moment. Same problem is on the base ball-joint.
Solution for this would be to have the base of the joint angled of around 45° in the direction of their leg, so that movement will be limited of roughly the same amount in both directions.
ID:	62992   Click image for larger version
ID:	62993   Click image for larger version
ID:	62994   Click image for larger version
Old 07-12-2008, 01:47 PM
Some figures I did not post previously to give an idea of size of machine.
Distance between the two base is 950mm. Witdh of base hexagon is 1000mm, platform is 300mm. Legs can extend from center of joints from 550mm to 950mm.
Old 07-12-2008, 01:55 PM
Hexabot electronics
Here the electronics box. On the left side, from top, mains filters and transformer and power supply board, with high voltage for pwm stepper ( around 35-36V ), 12V and 5V.
On the right side mainboard with pic16f877a controller. This will receive command from PC by serial port and convert it to dir and step commands for all the driving boards.
In the center there will be the stepper driver boards ( 8 in total ), only one
built at the moment...
On the top right space is for mill driver board, with digital variable speed controller, still to be designed and built.
Old 07-12-2008, 02:05 PM
Hexabot software
A screnshoot of the alfa version of the controller program. It reads a standard Gcode program from any cam program.
In the left window there are X,Y,Z position and A,B and C angles ( or other option will be vector direction, but is not standard in gcode ), feed speed, spindle speed and tool number.
The program is parametrized with the real machine size and a model in directx is built in the right windows. The platform is then moved in the correct X,Y,Z and angled as specified. Then it simply measures the distance from the ball-joints centers ( You can see in L1...L6 ). Movements are interpolated from one gcode position to the next in delta-T time steps ( around lets 1/10 of second ) and number of steps for motors in the correct direction is sent to the mainboard circuit throught serial port.
  #11   Ban this user!
Old 07-12-2008, 02:27 PM
Milo is on a distinguished road
Hi Bedo
Great project. Keep up the good work. Could you tell us
about the math involved?
  #12   Ban this user!
Old 07-12-2008, 03:11 PM
for Milo
Math is really simple, I do no calculation at all ! as I tried to explain in the software post, I made a CAD replication of the machine with the same size of the real one with directX 9. In the software You can see it moving as simulation.
I simply mode the the platform object in the correct position given by X,Y,Z of gcode and orient by the A and B angles. Then when You have the platform in the position You need, You simply take the distance from the ball-joint centers and You have the actuators lenghts. Some checking is done at this point not to reach the end of movement for length of legs or ball-joint angles.
If this test is not passed the position is not reacheable with current machine setup and program stops.
Then the program simply sends the correct number of steps for that delta-T of motion to the control board.
Starting from a know platform position ( all actuators retracted ) You will move the platform in the position You need simply setting the correct lenghts of the legs taken from the directX simulation !
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
sell CNC Woodworking Machine,CNC Advertising Machine zhangrui1588 Product Announcements & Manufacturer News 0 05-30-2008 08:43 AM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
G Code Variances from machine to machine? Miguel Gonzalez G-Code Programing 16 03-28-2007 03:31 AM
Rotary Hexabot Platforms chuckknigh DIY-CNC Router Table Machines 49 05-21-2004 01:02 AM
