Old 07-05-2008, 11:44 AM
theboneman's Avatar
theboneman is on a distinguished road
Roland Scanner and DIY CNC Router
This is probably a very simple issue but I am new to "Home-built" routers and I am hoping someone out there might be able to help me out here. I've been using a Roland PIX-3 scanner for years and have amassed a large number of scanned objects. I have been using an MDX-3 to do the cutting of each part one at a time.(Which is incredibly slow) Recently I have been building a DIY router to increase the number of parts I can cut at one time. I have purchased Rhino 4.0 software and Mach3 to drive the unit. Now the problem: I can move the Picza PIX file into rhino and convert it to DXF or most any other format for that matter with no problem. I can even modify it in Rhino if I wish. However, I can't get the mac3 software to creat a g-code or even recognize the file. I try to load it but it just freezes up.These are fairly large point files generally a scanned relief 3" x 5". I really need to use these scans for the project I am working on. How can I convert them into something my home-built can use? Do I need different software?
Thanks,
The Boneman
Old 07-05-2008, 12:07 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
One way I have used:
1. Take the Rhino file, save as stl (stereolithography) -- BINARY.
2. Load it into stlWork2. (available from IMServ -- advertises on the CNCZONE, and they have a trial option.)
3. Fill in the tables: speeds, tools, offset, etc,
4. Make a dnc file - load into MACH2/3
5. Mill.
Ok thats a few steps - but stlWork2 is pretty cheap compared to RhinoCam or other conversion to G-Code. I'm sure others will have some good inputs for you too. I'm not associated - just like the software.
Welcome Aboard - and,
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 07-05-2008, 01:22 PM
awerby is on a distinguished road
Mach3 is a great program
but it's mostly for actually running a CNC mill. The "Lazycam" software it comes with is only good for converting 2-d art, which is why you're having a problem with your 3-d scans.
Save your scans as STL, and download Freemill from the Mecsoft site:
http://www.mecsoft.com/Mec/Products/FreeMill.shtml
It's a simple program for generating G-code toolpaths to carve 3d parts on a 3-axis mill. It's free, and won't time out. If you're willing to pay a little for a faster and more flexible program, try the demo of DeskProto Lite:
http://www.deskproto.com/download/download-dp.htm
and check "DeskProto Lite Version" - it will run for a month before asking you to buy the program (I sell it for $330).
Andrew Werby
www.computersculpture.com
Old 07-05-2008, 11:13 PM
theboneman's Avatar
Thanks guys for your help! Both of your suggestions seem to work. However, only the stlWorks software (Now that I can get the file to load) allows me to use the fine toolbits I need for the level of detail I require. Currently, I perform a "Draft Cut" with a large toolbit then work my way down to engraving tools or flat end bits as small as .015 on a finish cut strategy. My MDX-3 allows me to define the size toolbit whereas the other two programs just allow you to select from a dropdown menu or from very limited parameters. The Freemill and the DP4 are great but they don't seem to get down to the very small toolbits I need. While investigating this software, I now have a couple more questions: How do I define my DIY router in the software for my custom bed size travel? (30" X 32" w/Acme 1/2-10 anti backlash screw movement with 1.8 steppers with limit switches all around.) Lastly, is it possible to use the roland software on my DIY machine? The MDX-3 software bundle includes the software for the the larger machines like the MDX-650. Is it usable?
Thank you both for your input. I do appreciate it.
Building a cnc router with an old printer and an old scanner codemaster Open Source CNC Machine Designs 13 07-31-2011 11:44 PM
Roland MDX-15 / MDX-20 kilroy1979 General Metal Working Machines 2 09-27-2009 02:42 PM
Router mounted david scanner irk3 Digitizing and Laser Digitizing 7 06-10-2008 02:30 PM
Roland EGX 3O and need new software thegimpster Engraving Machines 3 01-03-2008 02:21 PM
Has anyone used a Roland 3D scanner buscht Digitizing and Laser Digitizing 1 04-10-2004 02:57 PM
