Dear CNC router experts: I am working on the design of a very small CNC router for wax in jewelry applications. It is a fixed gantry, moving table machine and it must have a 4th axis to allow carving wax for rings. However, since the machine is so small, it is not practical to mount the rotary axis (A) on the table. So, my question is: Am I right in assuming that, for an XYZA machine, where A is a rotary axis ("barbecue spit") parallel to X (the gantry), I really don't need movement in the Y axis (the table) when using the rotary axis? - provided, of course, that the A axis is perfectly aligned under the spindle. I think this is true and, if so, the design will be much simpler and rigid. Also, I would only need 3 stepper drives: one for Z, another for X and the 3rd would be "shared" by Y and A. Nelson |
| I think it depends on how complex your shape is. Very likely you will be using a small ball nose cutter. I can imagine some profiles which would require the cutter to do an undercut, which is not possib le when the the spindle and fourth axis are centerd. However if the fourth axis can move away from the center of the spindle the tool can approach from a different angle.
| Thanks a lot for your replies Actually, after posting I found a recent contribution by HuFlungDung which confirms my assumption: On the thread "4th axis CAM" (thread 60323 post #7) HuFlungDung says that "Any cad system with scalable output for the Y axis could be set to output A axis code" (see the post for details) So, in a sense, in this situation, axis A "replaces" axis Y and you donīt even have to use 4axis softaware - standard 3D or 2.5D software can be "fooled" to route a band when actually "thinking" that is is carving a strip... Thank you all Nelson |
| But what I said is also true; if you want to do really complex shapes on a 4th axis then you do need Y in the equation.
| Dear Mike Stevenson: Thanks for the encouragement. Dear jdr: I am not sure I understand the details of your post: if you mean that these packages use simultaneously XYZ and A, then I would be in trouble. But, if you mean, as I understood, that the packages use XYZ in the 1st 2 setups and then XZA on the 3rd setup, then I will be OK, since my design does have a Y axis. It simply cannot use the 4 axis at the same time; you either mount the work on the table and use XYZ OR you mount the work in the chuck and use XZA. This is because the 4th axis is mounted on the "floor" of the machine, along with the posts for the fixed gantry and the rails for the moving table. If and when I have a working prototype, I wil post full details. Anyhow, the restrictions with certain software are only academic for me: I canīt afford these expensive jewelry packages - this is a hobby, not a business; I intend to use only free software or software that I write myself... Nelson |
| Some parts will work, others wont. An easy, no-math test to determine if you need the Y axis for a part would be to draw lines radially from the center of the A axis through the part. Make the lines as thick as your tool diameter. If the line leaves the part and crosses it again, then you cannot cut without the Y. As an example, imagine a part shaped like number "6". Center the circular part on the A axis and draw lines radially from that point. If the inside edge of the top part of the "6" is straight and along the radial line (again, the line is as thick as the tool diameter), then you can cut it on a XZA setup. If the part is curved/hooked, then the radial line will leave the circular part then re-enter at the hook. If the top tail is thinner, then when you rotate the A, the top of the tail will hit the tool, but the bottom part wont. The gap between that line and the part will be impossible to cut without the Y axis. You would have to rotate the A until that area points up toward the tool, then move the Y over to it. Just thinking out loud now, but would it be possible to extend the capabilities of an XZA system as proposed by using a tool that has a narrow shank and a ball shaped cutter? I would think you could gain some undercut capability limited to the difference between the shank and cutting edge radius. Bryan. |
| Trade offs between Moving Gantry and Moving Table | gregmary | DIY-CNC Router Table Machines | 11 | 04-22-2011 02:48 PM |
| Problem- Mach3 y axis dc servo jumps when moving small increments only. | mif73 | Mach Software (ArtSoft software) | 5 | 09-15-2008 04:32 AM |
| Need Help!- Y axis moving without being programmed HMB-1 | carbidecraters | HURCO | 1 | 06-22-2008 01:51 PM |
| Moving Table vs Moving Gantry; Dremel vs Router | chuckknigh | DIY-CNC Router Table Machines | 32 | 03-27-2007 09:48 PM |
| Axis are not moving | Reef Guy | Mach Software (ArtSoft software) | 4 | 09-13-2006 09:42 PM |
