Old 09-16-2004, 08:24 AM
Tasos_Eco is on a distinguished road
Newbie looks for help! :-)
Hello everybody!
Can anyone help me? I want to build a cnc for cutting plexiglass, wood an sometimes metal. The cutting area that fits to me is 25''x25''x4''. I would like the machine to be fast, not so fast that i have to pay it very much! :-)
I think, with the little things that i read, i need an
-DB1V2.0 CNC Parallel Port Interface
-3xGecko G210
for motors i don't know what i should buy? What should i buy?
And last question, if i would like to add 2 more axes what should i do?
Old 09-18-2004, 10:49 AM
samualt is on a distinguished road
Whats your price range? If I were you I'd look at getting some plans. Plans make things so much easier and faster! See the Sticky message at the top of the forum for some plans.
As far as motors, I like big motors but that makes things so much harder. I use big honking nema 42 (really big), 1500 ozin peak, that have to be geared down. But I have seen people use small 140 ozin motors that are just as good for their application. Are you planning on using a big wood router or something like a Dremal? It makes a difference. If your going to be cutting metal you probably need something a little bigger than 300 ozin (guesing).
As far as two extra axis you should look at the Rainea CNC Machine. Thats one way to do it.
Also, depending on your price range, you may just want to buy a machine. Ebay always has some interesting machines for auction, I'd check Ebay first. But you might also try the Liberty CNC Machines. That looks about the size your talking about. Granted, you can build one yourself for much cheaper, it just depends on what your looking for. Also check out Cheap CNC. They have kits.
From your questions I think my best advice is look for some plans. You will save yourself a lot of time and trouble. Hope some of this rambling helps!
Old 09-23-2004, 04:57 AM
samualt, thank you very much for your replay it was very helpful... have a nice day!
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-08-2011 12:16 AM
Complete Newbie seeking for help. - Clisby mini machines. some8 Mini Lathe 11 03-13-2006 09:23 AM
Autocad user has newbie SW/CNC questions cadesignr Solidworks 7 02-11-2005 02:19 PM
I am a NEWBIE rsera DIY-CNC Router Table Machines 4 03-22-2004 10:35 AM
Newbie says HOWDIE! cadesignr Autodesk Software (Autocad, Inventor etc) 1 03-21-2004 12:19 PM
